Sway bar drop brackets or extended links?
rust can be a determining factor here, as the bolts that attach the sway bar to the body like to snap right off if you look at them funny.  :(
But either way, I prefer longer sway bar links.  bonus points if you get them with disconnects :D
The angle between the sway bar link and the end of the sway bar is supposed to be pretty close to 90 degrees when the vehicle is sitting at normal ride height.
On a lifted MJ/XJ, you might have trouble getting there without moving the sway bar brackets as well as getting longer links when the lift gets over about 3 inches.
My MJ with a 3.5" lift has longer links AND relocating brackets for the sway bar mounts that push the sway bar mount down and forward to restore that 90 degree angle as shown in the picture.
I'm about 3.5" so that's good to know it make take both. Thanks!
Drop brackets also tend to move the sway bar a little forward toward the bumper. This can help match with your axle as most lifts also move the axle forward a little (which helps center the wheels in the wheel well at ride height).
Sent from my Pixel 4 using Tapatalk
Correct.  In my photo above, you will notice my custom-made drop brackets not only drop the sway bar mount about 1 inch lower from the frame, but they also move the centerline of the sway bar mounting clamp forward about 1.5 inches as well.
I had to do this in order to get the sway bar links to be essentially perpendicular to the ground when the Jeep is at normal ride height with my 3.5 inch lift.
