WanderingAccountant Posted April 10, 2020 Share Posted April 10, 2020 (edited) 1989 Jeep Comanche 4.0L Straight 6 / Manual Transmission / 4 wheel drive Build date: 1/89 Current Location: Tallahassee, FL Status: Daily driver Notes: Red exterior, grey interior, bench seats, vinyl seats and floor, floor shift. Just rolled over 100,000 miles and recently had the engine rebuilt. Current owner: Nick Gilpin Edited April 10, 2020 by WanderingAccountant Originally believed to be a longbed with a shortbed conversion, however the VIN decode reflected an original shortbed. Link to comment Share on other sites More sharing options...
JMO413 Posted April 10, 2020 Share Posted April 10, 2020 Build Date 1/9/89 Body Model JL61 *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 144 Zone 44-Syracuse 1AA U.S. Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Open BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Perforated Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 10, 2020 Share Posted April 10, 2020 13 hours ago, WanderingAccountant said: originally a long bed, but the previous owner purchased the truck 1999 and replaced with a short bed VIN decodes it as a short bed as JMO posted. the body code would be JL62 if it was a long bed. Short beds are denoted by 61. Looks good! Link to comment Share on other sites More sharing options...
WanderingAccountant Posted April 10, 2020 Author Share Posted April 10, 2020 @JMO413 this is incredible, thank you!! @eaglescout526 thank you for that, I was searching the listing for long v. short and didn't understand that it was denoted by the 61/62. I edited my post above to reflect the correction! Link to comment Share on other sites More sharing options...
Pete M Posted April 10, 2020 Share Posted April 10, 2020 oh my, just imagining the effort of swapping to the other size bed hurts my brain Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 10, 2020 Share Posted April 10, 2020 No problem. In my sig is the body style decode pdf if you are curious as to what the letters mean. Link to comment Share on other sites More sharing options...
WanderingAccountant Posted April 10, 2020 Author Share Posted April 10, 2020 @eaglescout526 very nice! I downloaded and will keep for reference. thanks again! Link to comment Share on other sites More sharing options...
jdog Posted April 1, 2021 Share Posted April 1, 2021 Selling Dealer: SIMS SPALDING INC Troy, PA Link to comment Share on other sites More sharing options...
