Need help figuring out what this vin means!
It’s registered as a 87 but.... originally had a 2.8 with a 904 trans and 207 transfer case AMC 20 rear d30 front.
I thought the 2.8 was only used in 86 but it’s also a swb 🤷🏽‍♂️
I......I can't even. I am not sure where to begin. It is only 7 so I can't run it. If I run it as a JT it comes up as an XJ. Buuuuuuutttttt… if I run it as an HT I get this which is unique as I have never seen a special paint code come up
*X1
-H9
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DDQ Transmission - 5-Speed Manual
EPD ENGINE - 2.5L I4 TBI GAS
GSC MIRROR - RIGHT BLACK
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JJA CIGAR LIGHTER - FRT COMP
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MD8 Delete Front License Plate Bracket
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
P99 UNRELEASED PAINT IN A SPECIAL SITUATION
PE4
QE4
RAC RADIO - AM/MTR
TBG SPARE TIRE - COMPACT
Maybe this one.
Build date 8/21/86
Body code JL62-but I think this makes it a long bed.
Is there a firewall or rad support VIN plate under the hood anywhere? Do you have the registration on hand to help verify it?
*X1
-H9
PE4 Punk'n Metallic Clear Coat
QE4 Punk'n Metallic Clear Coat
RAC RADIO - AM/MTR
Maybe this one.
Build date 8/21/86
Radiator support tag and inner fender tag
1 minute ago, jdog said:
My question is, where is it located at
Truck is in Montana.. watched it for probably 10+ years before buying it almost 4 years ago
Maybe a Renault prototype for from AMC for Renault to toy with? But I will be damned for none of us have probably ever seen that.
Another oddity... when I purchased the truck and cleaned it up there was faint lettering of some sort of race team down the side. The 2.8 was sporting a Offenhauser intake with ported heads and long tube headers
maybe a clue?
Another clue.. I have no doubt truck was originally black on black with gold pinstripes. Also has all the goodies ie a/c power windows and mirrors, tilt wheel and cruise control
Does it have the sticker on the door? Are there any other metal plates? Sorry for all the questions but this had me very intrigued.
No that’s it.
7 minutes ago, Koshon L said:
Notice there is a tag under the tag on radiator support.. Do I dare drill out rivets to take a look?
You can always separate the two and rivet both on the rad support. Is it aluminum in color? I say do it. It might unravel what this truck is.
