1953 Chevy COE Crew Cab
23 minutes ago, Manche757 said:
When will it be ready to paint? Decided on a color(s)?
We don’t know when it will be ready to paint. It all depends on how busy my dad is with work over the summer. It is going to be black because it is going to be a work truck and black is easy to fix if need be.
  • Replies 57
Posted Images
24 minutes ago, Manche757 said:
That looks pretty nice.
4 hours ago, Pete M said:
gloss black also scratches super easy.  it's a toss up.  :dunno:
I’m with ya there. But dad wants black so dad is going to paint it black. It should turn out good though.
5 hours ago, Manche757 said:
1953 Chevy COE in black
1953 Chevrolet COE Cab Over Engine Truck - One of the first ever modified  for sale: photos, technical specifications, description
1953 GMAC COE 4 door
1953 GMC COE "Custom Crewcab” | Cool trucks, Classic trucks, Trucks
Your Father's awesome truck building skills are exceeded by the way he raises his sons.
Thank you. We plan on doing a similar dual running board setup to that white truck. If you look closely at the white truck, the front wheel opening is larger than the rear due to it having half ton rear fenders. We used half ton front wheel openings to close up the front wheel openings on our truck.
Progress on the bed. We will put a piece of exhaust tubing along the sides to simulate how the original bedsides had the curl in them. It will also get stake pockets.
Those of you familiar with 47-54 GM trucks will recognize that these are actually 54+ style bedsides, the top is perpendicular to the bedsides, instead of at a 45 degree angle. This was done so that the truck could have a tonneau cover on it.
  • 2 years later...
It’s been a while since the last update. Not much has changed either. Running boards are mounted and filler panels are done.
When I was home for break, I buttoned up the piece that rotates the master cylinder.
More progress has been made. The filler panels between the running boards and the bottom of the bed and cab have been made.
The fuel filler neck has also been built. It is in the front driver side stake pocket.
IMG_5275.jpeg.106ec63f3e5c2c2ca101bd63921b9069.jpegIMG_5271.jpeg.b73d6c470aee440836c080d34775f877.jpegIMG_5270.jpeg.ef8b9c4cde96c2b839d008fac05f7630.jpeg
The filler neck goes into the stock 2000 tank. With the exception of the ABS being deleted, this truck will be a completely stock 2000 Silverado. All of the drivetrain is unchanged, as is the suspension.
  • 7 months later...
  • 4 weeks later...
More progress on this truck too. A modern hood release with a cable going inside the cab has been installed along with a filler panel to clean things up. Some front suspension parts have been picked up to from a closing advance auto parts store.
IMG_6136.jpeg.f533302187ff650a554bce05140bafd8.jpegIMG_6135.jpeg.1f9570977ceae08a2170f66f9df9a609.jpegIMG_6164.jpeg.f8381b8bc74ae5d0d6744d22900be1be.jpeg
16 minutes ago, Eagle_SX4 said:
Awesome truck. Just one question. How do you access the engine to do any service on it? That frunk appears to block the entire engine bay.
Excellent question. The engine and trans dipsticks are van units, so they are both easy to get to from under the hood. The spark plugs and related bits will be easy to get to from under the cab, and for any other work, the frunk and doghouse are being built to be removable fairly easily. Not quite as easy as most old vehicles, but should be about as easy to work on as the 01 Silverado that was the donor chassis.
The cab got primed about a month ago. It looks wavy in the pictures, but that’s mostly because the primer was still pretty wet when the pictures were taken. It really won’t need much bodywork at all.
The doors are almost finished and ready for bodywork now too, but no pictures.
I was sent back to Tucson with some grille parts to get chromed.
Grille parts have been dropped off at the chrome shop. The spreading of filler has begun on the cab. Fiberglass filler over anywhere that had welding done, then just a skim coat over everything else to get it perfect.
