BoneheadJeeper Posted February 25, 2020 Author Posted February 25, 2020 2 hours ago, Ωhm said: Disconnect C103. On the IGN SW side of the harness measure for voltage at C103_E, KEY ON (IGN SW connectors connected). Problem with C103 is C105 looks the same (6_pin). C103 will have YELLOW wire in cavity E. Yes, C267 and c268 were connected. C103_E (yellow wire) has 0v with key on.
Ωhm Posted February 25, 2020 Posted February 25, 2020 Mechanical question (Key Cylinder to IGN SW). With everything connected back up, back to normal, does engine CRANK over when key is in the START position? If yes, then OPEN circuit between C103_E and C267_I1 (YELLOW wire).
BoneheadJeeper Posted February 25, 2020 Author Posted February 25, 2020 The key literally does nothing at all. No fuel pump, no radio power, not a single thing works, no cranking of any kind, like its supposed to when you turn the key. It was driving, then everything just shut down. Its as if you went to start a car without a battery.
Ωhm Posted February 25, 2020 Posted February 25, 2020 2 minutes ago, BoneheadJeeper said: The key literally does nothing at all. No fuel pump, no radio power, not a single thing works, no cranking of any kind, like its supposed to when you turn the key. It was driving, then everything just shut down. Its as if you went to start a car without a battery. That's interesting. Maybe linkage between Key Cylinder and IGN SW or IGN SW adjustment. Anyone know DIY for IGN SW adjustment is, I can't seem to find it?
jdog Posted February 25, 2020 Posted February 25, 2020 Probably not the correct way but I have the key out, make sure the switch is in the off position. Install switch then run thru the function, start, run and acc, adjusting if needed. Stock 1988 swb 4.0 ax15 np 231.
jdog Posted February 25, 2020 Posted February 25, 2020 Also possible bad new switch. Just because it's new doesn't mean it is good. Stock 1988 swb 4.0 ax15 np 231.
jdog Posted February 25, 2020 Posted February 25, 2020 Just for grins, do either the interior lights or the headlights work, long shot but I'm wondering if the bulkhead is loose. Stock 1988 swb 4.0 ax15 np 231.
BoneheadJeeper Posted February 25, 2020 Author Posted February 25, 2020 10 hours ago, jdog said: Just for grins, do either the interior lights or the headlights work, long shot but I'm wondering if the bulkhead is loose. Stock 1988 swb 4.0 ax15 np 231. My jeep doesn't have the interior lights in it. That way when i bought it. But I do have head and tail lights, I can check dome lights for voltage when I get off work. Update: Dome lights have power inside the cab.
BoneheadJeeper Posted February 26, 2020 Author Posted February 26, 2020 Update: still no progress. I went back to the start of the post and triple checked everything suggested, still not getting any power to the ignition. I was online watching a few videos of a guy who went through and ohm'd his starter relay and checked for voltage, I wasn't getting the same reading he was. The 2 green wires going to it that have the plastic clips, have zero voltage. I'm also having a hard time finding info about this renix system for these 2.5 4cyls automatics. Everything I'm finding is for the 4.0. Another thing I rechecked was the fuse panel inside the cab, everything my key should be turning on, radio, etc has no power. Anymore ideas on what to check? Ive seen some people say its the nss and a few others say its not. Does anybody know a way to jump it over so i can atleast check to see if it's an issue?
jdog Posted February 26, 2020 Posted February 26, 2020 Pictures of said green wires, forgive me as I should have asked for this earlier but what year. Once I get back to the wiring diagrams I'll tell you which wire to disconnect and how to bypass the nss. Until then can I have you do one other thing and back probe the wires at the ignition switch with it on I'm looking for voltage. Can you give me all the wires readings. Stock 1988 swb 4.0 ax15 np 231.
BoneheadJeeper Posted February 26, 2020 Author Posted February 26, 2020 47 minutes ago, jdog said: Pictures of said green wires, forgive me as I should have asked for this earlier but what year. Once I get back to the wiring diagrams I'll tell you which wire to disconnect and how to bypass the nss. Until then can I have you do one other thing and back probe the wires at the ignition switch with it on I'm looking for voltage. Can you give me all the wires readings. Stock 1988 swb 4.0 ax15 np 231. I don't have a picture, but on the starter relay its the middle and bottom left. I can go to the video and find them but I'm at work rn so can't get a pic. But its an 87 sport truck base model. Swb. 4x4. Honestly I'm not sure what you mean when you say back probe. And what wires should i do that with.
jdog Posted February 26, 2020 Posted February 26, 2020 No worries and back probing is going from the back of the connector into the plug. So where the wires are coming into the plug. Stock 1988 swb 4.0 ax15 np 231.
jdog Posted February 26, 2020 Posted February 26, 2020 Middle wire goes to the starter, other one I believe is the signal wire from the column that tells it to start, neither should have voltage until the key is in the start position Stock 1988 swb 4.0 ax15 np 231.
Ωhm Posted February 26, 2020 Posted February 26, 2020 Upper right hand corner of screen. Click on USERNAME. Click on ACCOUNT SETTING. Click on SIGNATURE. Add INFO: YR, ENG, TRANS, etc, etc.
BoneheadJeeper Posted February 26, 2020 Author Posted February 26, 2020 3 hours ago, jdog said: Middle wire goes to the starter, other one I believe is the signal wire from the column that tells it to start, neither should have voltage until the key is in the start position Stock 1988 swb 4.0 ax15 np 231. Yes, I sat my volt meter up on hood and turned key to see if there was a change in the voltage. The guy i watched online, his meter would hold the max voltage shown until cleared so i had to watch mine.
BoneheadJeeper Posted February 26, 2020 Author Posted February 26, 2020 3 hours ago, Ωhm said: Upper right hand corner of screen. Click on USERNAME. Click on ACCOUNT SETTING. Click on SIGNATURE. Add INFO: YR, ENG, TRANS, etc, etc. Fixed. Thanks.
BoneheadJeeper Posted February 26, 2020 Author Posted February 26, 2020 3 hours ago, jdog said: No worries and back probing is going from the back of the connector into the plug. So where the wires are coming into the plug. Stock 1988 swb 4.0 ax15 np 231. When I get back home this evening, if the rain stops, I'll get you a reading.
Ωhm Posted February 27, 2020 Posted February 27, 2020 On 2/26/2020 at 8:44 AM, BoneheadJeeper said: Ive seen some people say its the nss and a few others say its not. Does anybody know a way to jump it over so i can atleast check to see if it's an issue? Using a testlight, connect the clip end to Battery Positive (B+). Probe D2_3 with other end. LAMP ON: P or N LAMP OFF: all other positions.
BoneheadJeeper Posted February 29, 2020 Author Posted February 29, 2020 On 2/27/2020 at 3:57 PM, Ωhm said: KEY OFF. Using a testlight, connect the clip end to Battery Positive (B+). Probe D2_3 with other end. LAMP ON: P or N LAMP OFF: all other positions. No change in whats been happening. What wire can i make hot in the ignition switch to get it going?
Jeep Driver Posted February 29, 2020 Posted February 29, 2020 26 minutes ago, BoneheadJeeper said: What wire can i make hot in the ignition switch to get it going? Do you have 12v at the red wire at the ign switch? If not, you need to trace that wire back to the fused link, find the break, fix it. And I'm not convinced your fused links are good. This will require you to literally, physically, trace that wire. Not picking and probing and testing here and there.
BoneheadJeeper Posted February 29, 2020 Author Posted February 29, 2020 14 hours ago, Jeep Driver said: Do you have 12v at the red wire at the ign switch? If not, you need to trace that wire back to the fused link, find the break, fix it. And I'm not convinced your fused links are good. This will require you to literally, physically, trace that wire. Not picking and probing and testing here and there. Yes i have 12v at the Red wire going into ignition switch.
BoneheadJeeper Posted February 29, 2020 Author Posted February 29, 2020 39 minutes ago, jdog said: have you back probed the connector yet? What wires you wanting me to bp? And with wires plugged into ign switch or out of switch?
jdog Posted February 29, 2020 Posted February 29, 2020 Into the switch, switch on and all of em. Stock 1988 swb 4.0 ax15 np 231.
BoneheadJeeper Posted February 29, 2020 Author Posted February 29, 2020 1 hour ago, jdog said: Into the switch, switch on and all of em. Stock 1988 swb 4.0 ax15 np 231. I removed the switch and done this without it mounted, not sure if it effects anything or not. But with key off, I'm getting 12v at red nothing else...with key on I'm not getting anything at red or any other wires. *When i say with key on/off, I'm moving the piece in the switch myself*
