Clutch replacement
My 1986 Comanche needs a new pressure plate. If I do any work it will be the whole deal...clutch, pressure plate, throw out bearing. It's a 2wd 2.5. Are there any pics of any bolts on the top of the transmission??? And can these be accessed from the engine compartment...under the hood? Any pics would be appreciated. I will have to do this on ramps or jacks. Any help would be Awesome!
Thank you!
Jim
8 hours ago, 70barracuda said:
bread trick for the pilot bearing
This all the way. Don't even bother with getting a puller tool. And instead of getting a bolt that is the correct diameter, I used a socket. Put a 6" extension BACKWARDS on the socket (meaning the extension is stuck into the open socket where you usually have it on a bolt head) and use that to hammer the pilot bearing out. Bread was so much easier than grease to clean up afterwards and you don't need a perfect fit to get enough hydraulic pressure.
