What is the best CPS out there for an 89 4.0L. Rain ,sleet, snow out and mine must be getting weak, left a wake this afternoon for a good friend and MJ wouldn't start, unplugged and plugged fired right up so I will be replacing soon, is MOPAR still available?
I had the same issue in my XJ. Dirty connector, had to do the unplug, plug about every 6 months. Finally just jumpered around the connector and never had the issue again. I left the connectors connected and just spliced wires around them, in case I ever had to replace the CPS.
Thats a good idea,I should measure volts, mine is original I believe so may just replace as it's 31 years old, sucked standing in pouring rain and sleet today to get at it, and of course lock tab broke off
The factory had a TSB and a kit to bypass the C101 connector so the two wires from the CPS went directly from the CPS connector through the firewall to the ECU. This was supposed to alleviate signal loss. I don't know if the associated kit (which was the CPS with the replacement wiring harness) is still available, but it should be easy enough to make up your own.
Cruiser, do you by any chance have the part number and/or instructions for that kit?
