90manche Posted December 24, 2019 Share Posted December 24, 2019 I got a 1990 Jeep Comanche sport with the 4liter in-line 6, I have had it for 3 weeks and in the time I have had it, it had randomly decided not to start 3 times. It will still crank, just not actually start, but I can bump start it fine, and if I wait 30 min or so it will start again, any ideas? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 24, 2019 Share Posted December 24, 2019 Sounds like CPS. Cruise has testing procedures on this to root out a bad CPS Link to comment Share on other sites More sharing options...
NHMJXJ Posted December 24, 2019 Share Posted December 24, 2019 Crank Position Sensor. That's how it begins … then one day you'll be driving along and it will stop running all together. Link to comment Share on other sites More sharing options...
90manche Posted December 24, 2019 Author Share Posted December 24, 2019 That’s what I was thinking it was, from what I’ve found. What is the easiest way to change that? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 24, 2019 Share Posted December 24, 2019 The CPS? There’s only one way to change it. You have to unbolt the two bolts holding the sensor in place on the drivers side of the bell house and then unplug it from the engine side. Be careful not to drop the bolts down into the housing. A decent length extension and an 11mm socket should take the bolts out. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted December 24, 2019 Share Posted December 24, 2019 I have gorilla sized arms and sausage sized fingers. For me I have to take the transmission crossmember and exhaust pipe loose and let everything hang down (supported by a jack stand) to be able to reach it. But don't trust me. If there is an easy way and a hard way to do a job I choose the extra hard way of doing it, every time. Link to comment Share on other sites More sharing options...
JMO413 Posted December 24, 2019 Share Posted December 24, 2019 32 minutes ago, 90manche said: That’s what I was thinking it was, from what I’ve found. What is the easiest way to change that? http://cruiser54.com/?p=50 Here's cruisers CPS test. I have changed a couple. Get a nice array of extensions. Some long some really long and couple shorts. Get a good swivel then figure the combination to reach the bolts. When you are going back together black tape on the socket to hold the bolts is a life changer! Link to comment Share on other sites More sharing options...
Warren Mohler Posted December 24, 2019 Share Posted December 24, 2019 if it's the first time being replaced you may find a hard rubber plug around it to keep trash out of bell sort of a pain in the butt, it will keep mice, bolts etc. out Link to comment Share on other sites More sharing options...
90manche Posted December 24, 2019 Author Share Posted December 24, 2019 Thanks for the help! I will plan on changing that ASAP Link to comment Share on other sites More sharing options...
EvilMJ Posted January 15, 2020 Share Posted January 15, 2020 My 89 did this to me twice recently in a period of 4 days. I replaced coil to no advantage, but replaced the ignition control module underneath (seemed fine when pulled), and have not had a problem since (been about a month and 1k miles). I will say, during troubleshooting, I had no spark from distributor or coil - hense my belief it was the coil or ICM. Link to comment Share on other sites More sharing options...
Drahcir495 Posted January 15, 2020 Share Posted January 15, 2020 On 12/24/2019 at 12:34 PM, JMO413 said: When you are going back together black tape on the socket to hold the bolts is a life changer! Was going to say that. Just awesome advice Link to comment Share on other sites More sharing options...
