mancheflo Posted December 24, 2019 Share Posted December 24, 2019 So just got off work and going to auto zone to get a gift card for my father in law and as I pull into the spot the Jeep just turns off, it’ll try to turn over all lights on and battery is good, any ideas? I’ve never had any problems with it starting in the past even when it’s been below 20 Merry Christmas to me 🙃 Link to comment Share on other sites More sharing options...
Drahcir495 Posted December 24, 2019 Share Posted December 24, 2019 My CPS started to give me a warning glitch before it went out completely. Just died and wouldn’t start - just turned over. After I fixed it, it seemed like it failed again; just cranked over. Gauge said battery was good, but I took it to advanced auto and had it tested. Turns out that battery had a bad cell in it. I hope something in here will help Link to comment Share on other sites More sharing options...
mancheflo Posted December 24, 2019 Author Share Posted December 24, 2019 17 minutes ago, Drahcir495 said: My CPS started to give me a warning glitch before it went out completely. Just died and wouldn’t start - just turned over. After I fixed it, it seemed like it failed again; just cranked over. Gauge said battery was good, but I took it to advanced auto and had it tested. Turns out that battery had a bad cell in it. I hope something in here will help Had the battery tested while I was there, he also tested some other stuff and said it was getting no spark so idk Link to comment Share on other sites More sharing options...
87MJTIM Posted December 24, 2019 Share Posted December 24, 2019 Does it crank, just not fire? Is it getting fuel? Do you hear the pump priming when you turn the key? You're at Auto Zone. Get a fuel pressure gauge and test FP. Fuel filter clogged? How old is it? Test the CPS with a multi meter. See Cruiser's Tip on testing the CPS. (I know Cruiser's Tip are Renix oriented, but the CPS testing is universal.) Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 24, 2019 Share Posted December 24, 2019 Unplug the cps for a few seconds and plug it back in and see if it starts Link to comment Share on other sites More sharing options...
Warren Mohler Posted December 24, 2019 Share Posted December 24, 2019 unplug and replug CPS a lot of times this will work if it's weak Link to comment Share on other sites More sharing options...
Eagle Posted December 24, 2019 Share Posted December 24, 2019 As others have already noted, the most likely suspect is the CPS. Link to comment Share on other sites More sharing options...
Ωhm Posted December 24, 2019 Share Posted December 24, 2019 Loose starter motor. Link to comment Share on other sites More sharing options...
mancheflo Posted April 11, 2020 Author Share Posted April 11, 2020 Any thoughts as to if this could be a fuel pump issue? Ran for about a month or so then do the same thing and now nothing Link to comment Share on other sites More sharing options...
