Question about Transfer Case swap
I just want to double check this because I found no where saying this swap wouldn't work. A 242 from a 99 Jeep Cherokee should mount to my Ax15 from a 93 Jeep Cherokee with no problems. I know I need to change the shifter linkage, and shifter gate bezel.
Thanks
5 minutes ago, derf said:
Double check the spline count of the two cases.  The electrical plug for the shift indicator is different.  Also if you have the disconnect axle you will need to convert to a one piece axle.
 Ok thanks for the info. I plan on doing a Cad delete soon on my truck so that shouldn't be an issue.
1 hour ago, derf said:
A case from a 99 won't have the vacuum actuator to run the disconnect system.
This doesn't mean you HAVE to switch to a one piece axle, or that you HAVE to lock the actuator. I have used THIS PRODUCT and love it. Being able to choose 2wd low is fantastic. Honestly I use 2wd low more than 4wd in my daily driving.
Just another option.
That would work too.
2 minutes ago, omega_rugal said:
lock the CAD, same thing... any advantage of switching to one piece axle?
The one piece is stronger than the locking cad method especially if you get the later axle shafts out of a Jeep Cherokee with the bigger u joints 96+ from my understanding from looking into it for myself.
Main advantage is reliability.  The CAD mechanism is prone to failure and is needlessly complex (while providing questionable mpg benefit, which was the reason they did it).  Locking it in place helps, but it's still more parts to fail...one piece shaft is reliable and simple (and a lot easier to work on if you need to swap a shaft).
...that said, I'm still running CAD in the front of mine because I'm too lazy to get around to installing the seal (especially in the cold).
