Does anyone know if you can put a Renix throttle body on an HO intake. I know you can’t put the whole Renix intake on an HO head. Thanks
27 minutes ago, Warren Mohler said:
if you made an adapter or drilled intake maybe, adapted the link rod,  my question is why would you want to?
I need an engine, but don’t want to do an HO swap and can’t find any Renix era Jeeps.
8 hours ago, DirtyComanche said:
You're way better off using the HO TB, intake, fuel rail, etc, and then adapting the Renix TPS.
Ok. Will I need to swap any dash stuff then?
Why?
Too much work for little or no gain.
Put the motor in per the guide and carry on.
