LS 5.3 Comanche Burnout
ogjeep
  • ogjeep changed the title to LS 5.3 Comanche Burnout
31 minutes ago, kryptronic said:
I'll probably never swap an LS into one of my trucks, but I'm really tempted after seeing this.  Looks like a blast.
I hear ya , Ive had like 30 Comanches. This is my first Ls swapped one. NO shortage on fun! Reliable good on fuel and just GOBS of power.
Did you use store bought engine mounts or just fab your own to sit the engine lower to clear the intake?
These would have to be fabbed...the Novak ones sit the engine too high to use the truck intake and require a car intake. (Even then, if you have a DBW TB, it still seems to need a little clearancing work on a hood support beam)
Sent from my Pixel 4 using Tapatalk
The Novak mounts also explode if you look at them wrong.  Really bad design.
