jeepmj_tj
Everything posted by jeepmj_tj
  1. Ok. Care to share pics?
  2. Did you use store bought engine mounts or just fab your own to sit the engine lower to clear the intake?
  3. Is that the car intake? With where you positioned the motor would the truck intake clear the hood?
  4. Thanks for the links
  5. Any update on the window swap?
  6. I have a 91 with factory buckets and mini console. I switched to a full xj console years ago but want to switch back and add a third seat for my little one. I have seen the Dakota seat options but am un clear if it mounts separate or requires the passenger seat. Obviously a seat/console would be best! Has anyone added something with factory buckets? thanks
  7. Its a gm based column. Did they change the knob from those of any gm car during that time period?
  8. something like this, but possibly with out covering the lights.
  9. Have you thought about making any rear quarter panel guards?
  10. Any one know what the length of the comanche m20 axle shafts are? Left and right are suppose to be the same according to the part numbers. Need to finally covert my rear end to 6 lug and wondering if any of the fsj ones might be a similar length and bearing offset.
  11. I don't remember seeing, but have you tried putting some shocks on it?
  12. Awesome, thanks for fixing all the broken links. Camper turned out great! Have you done any upgrades or changed anything since the initial build?
  13. thats a helluva upload..... :cheers:
  14. do you have them hosted somewhere else?
  15. none of the pictures are working anymore. :needpics:
  16. Ah ha. Didn't realize I was viewing in the mobile site. Edit. I'm actually using the full version. Still no icons I started googling images for ideas over the weekend. You don't realize how much time passes when you stumble into a 100 plus page thread on expo portal about storage and sleeping threads.
  17. Something must be incorrect with my iPad. The reply window doesn't have any of the tool icons to click on for adding pics, vids, links etc.....
  18. http://forums.bowsite.com/tf/pics/00small61772734.JPG http://i.ytimg.com/vi/Z1yJWhRWBzA/maxresdefault.jpg Where is the options for inserting images? I can't remember the image code.
  19. Let's see how you have "set up" your camper shell. Storage, bed, drawers, etc.....
  20. if i make some, I have to decide how much of the lower body lines I want to cut when I fab up some rear overhang sliders.
  21. nm, I think I finally found it.
  22. anyone know more details about this truck?
  23. bringing this one back alive. anything new out on the market since 2009?
