1989commanche Posted October 16, 2019 Posted October 16, 2019 Got me some of those newfangled switches for my aux lights with a separate input for the labels to illuminate with the dash -interior lights. Where is the best place to run the wire that supplies power when dash lights are on. I like to do things right and don’t want to just start hacking into wires under the dash. Is there a wire going to the radio or somewhere else that is easy to get to? The upper pic lights when switch is on but label is supposed to light with the dash lights. Also does anyone know a vendor that sells a switch panel that replaces the oem clock panel. I have seen them somewhere but can’t remember who was selling it. I think it held 4 rocker switches.
Ωhm Posted October 16, 2019 Posted October 16, 2019 Incandescent bulbs or LEDs? Dash lights work off the DIM circuit of the Headlight Switch and and can be dimmed.
1989commanche Posted October 16, 2019 Author Posted October 16, 2019 I’m pretty sure they are LED indicator lights. My dimmer hasn’t worked since I got the truck and I haven’t spent the time to change it out. I like full bright anyway.
Ωhm Posted October 16, 2019 Posted October 16, 2019 If you don't have the Cargo Lamp Switch, harness should still have the connector (C366). If you don't have the Fog Lamp Switch , harness should still have the connector (C176). Look under dash left side. Problem is both C176 and C366 are identical (look alike). Both use Pin_A for ground and Pin_B for B+. C366 is hot when PARK lamps are lit, C176 is hot when HEADLAMPS are lit. If you have both available, you'll need to determine which is which.
fiatslug87 Posted October 16, 2019 Posted October 16, 2019 3 hours ago, 1989commanche said: Also does anyone know a vendor that sells a switch panel that replaces the oem clock panel. I have seen them somewhere but can’t remember who was selling it. I think it held 4 rocker switches. I have a used one, I went another way, I'll pm you.
1989commanche Posted October 17, 2019 Author Posted October 17, 2019 3 hours ago, Ωhm said: If you don't have the Cargo Lamp Switch, harness should still have the connector (C366). If you don't have the Fog Lamp Switch , harness should still have the connector (C176). Look under dash left side. Problem is both C176 and C366 are identical (look alike). Both use Pin_A for ground and Pin_B for B+. C366 is hot when PARK lamps are lit, C176 is hot when HEADLAMPS are lit. If you have both available, you'll need to determine which is which. Great I have neither switch installed. So I just need to check to see which connector is which and tie on to the parking lamp lead from connector C366. Sounds simple enough. Thank you.
agamble Posted October 17, 2019 Posted October 17, 2019 6 hours ago, 1989commanche said: Got me some of those newfangled switches for my aux lights with a separate input for the labels to illuminate with the dash -interior lights. Where is the best place to run the wire that supplies power when dash lights are on. I like to do things right and don’t want to just start hacking into wires under the dash. Is there a wire going to the radio or somewhere else that is easy to get to? The upper pic lights when switch is on but label is supposed to light with the dash lights. Also does anyone know a vendor that sells a switch panel that replaces the oem clock panel. I have seen them somewhere but can’t remember who was selling it. I think it held 4 rocker switches. Prime4x4 sells a panel that replaces the clock panel.
1989commanche Posted October 19, 2019 Author Posted October 19, 2019 On 10/16/2019 at 3:37 PM, Ωhm said: If you don't have the Cargo Lamp Switch, harness should still have the connector (C366). If you don't have the Fog Lamp Switch , harness should still have the connector (C176). Look under dash left side. Problem is both C176 and C366 are identical (look alike). Both use Pin_A for ground and Pin_B for B+. C366 is hot when PARK lamps are lit, C176 is hot when HEADLAMPS are lit. If you have both available, you'll need to determine which is which. Do you know what color the wires are supposed to be for 366. There are quite a few wires under there that have been cut and are just zip tied to something. At least 6 or eight of them. I would rather they light up when parking lights are on. Don’t always need headlights on.
Ωhm Posted October 19, 2019 Posted October 19, 2019 29 minutes ago, 1989commanche said: I would rather they light up when parking lights are on. Don’t always need headlights on. C366_B is ORG/BLK. Seems all DIMMING circuits are the same color code. C157_B is strictly PARK lamps. Color code should be DK BLU.
1989commanche Posted October 20, 2019 Author Posted October 20, 2019 There were a few instrument lamp sockets just dangling about. I just used one of those. On when key on and parking lights lit.
1989commanche Posted October 20, 2019 Author Posted October 20, 2019 Got a better shots now that it is darker out
1989commanche Posted November 4, 2019 Author Posted November 4, 2019 Got this from fiatslug just what I was looking for a little sanding and a few coats of paint it’s good as new.
thecodemonk Posted November 4, 2019 Posted November 4, 2019 I got my 4 switch panel on ebay...since the ebay app gives $5 off every so often, it makes it really cheap.
AZJeff Posted November 6, 2019 Posted November 6, 2019 Where did you get those cute switches with the graphics?
1989commanche Posted December 14, 2019 Author Posted December 14, 2019 I got them at the Pomona off road show. But there are plenty of folks on Amazon and eBay that sell them. If you need I should have the contact info of where mine came from.
AZJeff Posted December 14, 2019 Posted December 14, 2019 13 hours ago, 1989commanche said: I got them at the Pomona off road show. But there are plenty of folks on Amazon and eBay that sell them. If you need I should have the contact info of where mine came from. Thanks!!
