eaglescout526 Posted September 7, 2019 Posted September 7, 2019 Has anyone ever had cruise control just stop working? I go to engage it one day as I was driving home and I smelt an electrical burning smell. I have replaced everything(including wiring harness) with a spare set I had. I did get it to engage for maybe a minute with the old regulator but now nothing. I have done the FSM adjustment and it engages for a second and it stops operating. I have vacuum where I need it to be and I am getting vacuum from the cannister. Anyone just run into this and be baffled by why it won't engage? Does anyone have the dealer tool? AM PC-1-R?
eaglescout526 Posted September 8, 2019 Author Posted September 8, 2019 I’ve tested both factory and aftermarket switch. I’m gonna look into my vacuum harness on the engine side tomorrow. I put hell of a battle up today just electrically. Seems like everything functions as it should. Don’t know if the regulators(computers) do.
eaglescout526 Posted September 8, 2019 Author Posted September 8, 2019 Yup. I keep testing them with the pots in different positions. H.O. Won’t work with Renix sadly. H.O. Computer has cruise built in so it’s plug and play. Renix cruise isn’t a PITA, well installing it is but once it’s in there and some fine adjustments it’s awesome to have. I’ve just never heard or have cruise just lay down and die until now.
eaglescout526 Posted September 8, 2019 Author Posted September 8, 2019 (two hours ago)Well damn...I blew something on the regulator. Plugged in the old regulator after doing some adjustments and poof a plume of smoke. Did some tracing on the board to the wiring after I got home and found it is the white wire that leads to the servo. Servo bad? I don't know. All I know is that it has Ohm resistance that is less than infinite according to the FSM.
eaglescout526 Posted September 9, 2019 Author Posted September 9, 2019 1 hour ago, saveevryjp1998 said: I think you misunderstood. I could go either complete ho setup or renix. So I meant why bother with a renix setup if I have both to choose from in front of me. Oh, yes that makes more sense.
omega_rugal Posted September 9, 2019 Posted September 9, 2019 i thought Renix era cruise were electronic, mine had a square box with an electric motor inside...
eaglescout526 Posted September 9, 2019 Author Posted September 9, 2019 53 minutes ago, omega_rugal said: i thought Renix era cruise were electronic, mine had a square box with an electric motor inside... Its an electro-vacuum set up. So far I'm at a loss. The original regulator blew a resistor. The new one just won't do a damn thing. Everything seems to be in working order but I can not tell for certain. It all worked prior to tearing out the dash to install AC. But that is it. I haven't disturbed the set up and all I did was unplug the servo from the vacuum line and unmount it to move it out of the way for the moment. The only thing I found on the dash side was the ground cable that Cruiser recommends to do was torn away from the mounting stud. That has since been repaired.
omega_rugal Posted September 9, 2019 Posted September 9, 2019 mine has no vacuum stuff, all electric, i rewired it as a crude electronic throttle control, the OEM speed controls are long gone and i have a manual tranny so cruise control it´s useless for me... with this setup i accelerate, shift to top gear and lock the throttle in place, with 2 buttons for adjust + and - , pressing the brake resets the system... the only thing left to do is find a way to tune the + and - buttons: + is rather slow to increase the rpms but i have to quickly tap the - or else the throttle goes all the way down...
eaglescout526 Posted September 9, 2019 Author Posted September 9, 2019 That honestly sounds like an aftermarket kit. I think I'm gonna bet I need a new regulator.
eaglescout526 Posted September 9, 2019 Author Posted September 9, 2019 I need to get a vacuum tester and gauge, but as far as I know everything works. I have done light tests and volt tests at all electrical connections to see what does what.
Red Mistress Posted September 9, 2019 Posted September 9, 2019 AMC cruise control tester, this guy will let you borrow it. http://www.ifsja.org/forums/vb/showthread.php?t=174387
eaglescout526 Posted September 9, 2019 Author Posted September 9, 2019 I’ll have to get in contact with him. You would think more of that tester would be around as it seems Dana was the leader in cruise control tech back in the day.
eaglescout526 Posted September 17, 2019 Author Posted September 17, 2019 Well I finally figured it out. After some rigorous testing of the entire circuit and swapping parts around, it boiled down to one regulator blowing a couple resistors and the other being inop. JMO sent me his old regulator that allowed me to come to this conclusion. Nice to have cruise and something functioning again.
WahooSteeler Posted September 17, 2019 Posted September 17, 2019 13 minutes ago, eaglescout526 said: Well I finally figured it out. After some rigorous testing of the entire circuit and swapping parts around, it boiled down to one regulator blowing a couple resistors and the other being inop. JMO sent me his old regulator that allowed me to come to this conclusion. Nice to have cruise and something functioning again. Any more detail and/or pics of the repair? I have non-functioning cruise also and while it could certainly be one of many things, this could be good info to start with troubleshooting.
eaglescout526 Posted September 17, 2019 Author Posted September 17, 2019 9 minutes ago, WahooSteeler said: Any more detail and/or pics of the repair? I have non-functioning cruise also and while it could certainly be one of many things, this could be good info to start with troubleshooting. Actually...it’s really was a matter of swapping out the regulator(the yellow box) and testing it. There is a factory testing procedure for testing the regulator, on one side is two pots both get positioned at the ten o clock position and the third one gets turned all the way to the left. I used a test light to test the stalk and brake light functions.
eaglescout526 Posted September 17, 2019 Author Posted September 17, 2019 9 minutes ago, WahooSteeler said: Gotchya......Thanks No problem. I can assist it need me.
Minuit Posted September 17, 2019 Posted September 17, 2019 Wish I had time to see what's inside of one of these things and see if I could fix it
eaglescout526 Posted September 18, 2019 Author Posted September 18, 2019 24 minutes ago, Minuit said: Wish I had time to see what's inside of one of these things and see if I could fix it Well when ever you find time I have my busted one that I may or may not be able to fix. Solder is a bit out of my skill but might try it if I find the right resistor needed.
Minuit Posted September 18, 2019 Posted September 18, 2019 Wish I had time to see what's inside of one of these things and see if I could fix it
jdog Posted September 18, 2019 Posted September 18, 2019 I've got one or two I can send you so when you get a chance to look atStock 1988 swb 4.0 ax15 np 231.
