Rear sliding window SE-PA $1
MeanLemons
Who want to trade their single piece for my sliding rear window?
I have no foggiest clue of how to remove it or install new one, so let’s come over to my garage and swap them? Lol
I'm this close to just smashing it out and installing a plexiglass sheet.
Wish you where closer. I have a solid one out and want another slider. If you diy I'd take out your headliner. I didn't and when I removed mine it tore it up. As said above you can buy the removal tool from hobofrieght you just kind of "saw" it out. Putting it in though is a b*@ch. I tried and failed so just paid someone to do it.
I’ve cut 1.5 out. I used a box cutter for the broken one and used a bicycle brake cable for the not broken one. Just pull the rubber “gasket” out from the outside then cut the glue out. I need to cut my slider out and put in the solid rear window I got, but I’ve been too lazy to deal with all the glue.
Archived
