Gjeep Posted February 2, 2020 Author Posted February 2, 2020 Spent some time cutting out the bumper corner driving light recess. An incredibly time consuming process to get it right -- mix of dremel, x-acto, assortment of files, wet sand paper, and finally SEM trim paint. One down and one more to go. Also got the bumpers back from powder coating and mounted the front one.
Gjeep Posted February 8, 2020 Author Posted February 8, 2020 Slowly but surely...Front end. Takes forever to get the bumper lined up and all the pieces attached to it straight.
Gjeep Posted October 15, 2020 Author Posted October 15, 2020 It's been a while since I posted on this thread -- as I've been focused on my MJ. Currently out and about with the 97 XJ really driving it for the first time since I bought it back in May 2019! Broke in the brakes, and stretching the legs of the various engine and suspension mods made. Running good! (I will say it did take some effort getting this thing started... seems the fuel may have lost its octane as I couldn't get it to start until I poured 5 gallons of fresh 92 octane fuel in the tank.) I'm picking up the recovered headliner, overhead console and visors this morning... And at the same time will be dropping off the MJ upholstery to get those seats done. Once I'm finished painting the MJ, I plan on letting the paint cure for about a month before re-assembly begins. In that time, I'm aiming to get the agate interior into this XJ.
Gjeep Posted October 18, 2020 Author Posted October 18, 2020 The weekend has given me the chance to focus on the XJ...I decided to refinish the interior panels as they were all various shades of the agate color. Probably due to production year/ paint batches. I just knew I would eventually regret not just handling refinishing these -- so adhesion promoter, color, and low sheen clear is now covering these parts. The cargo area panels I’ll do last as I need to trim-out the passenger side quarter panel for the custom recessed sub box. After that I’ll refinish those also. Getting there...
Gjeep Posted October 21, 2020 Author Posted October 21, 2020 Got up extra early to tinker/ trim on the XJ’s passenger side interior quarter panel for subwoofer installation. Nothing quite as terrifying as botching the last NOS agate panel in Chrysler’s parts location. The below is my mist gray rough-cut junkyard tester panel from a while back. This cut follows both the enclosure manufacturers recommendation and the outer most line of the quarter panel insert. To me, it just looks to be too big of an opening. It loses the character lines of the original panel. The lower two pics are of the NOS agate panel I cut keeping to the inner most cut line with enough lip so I could keep the interior panel flush to the speaker enclosure. I used some thick foam tape to guide my eyes and be there as insurance should I slip up. Lucky for me I didn’t. First pass was the easier straight length cuts to the plastic opening. Next, I cut the corners triangular with plenty of room so I could carefully round out the openings with the Dremel. First step was marking the curve, then I cut. All went well…Many passes with 800 grit wet sandpaper and all looks factory to the eye. Since my goal is aesthetics on this sub, I decided to follow the more inside line of this panel. Really, I only saw two good options for this panels cut…The original wider cut top pic (mist gray panel) or the bottom smaller cut (agate panel). Another goal of this installation is making sure the speaker is centered in the carpeted area. But the way this enclosure was built, it wasn’t going to happen without extra effort. Further back on my build page around this topic I had already trimmed about an inch of vertical inside sheet metal to move the box back to center things up…But since I’ve decided to go with the smaller trim of the quarter panel plastic, I need to follow the line of the subwoofer and around out about 1/8” left and right of the speaker on the interior panel to make all right. Dead center top and bottom carpet space. Last step will be refinishing the agate color on the panel with the other cargo area panels and recovering the enclosure face with OEM Jeep fuzzy carpet material for perfect match cargo area. I got this carpet off the back of a ’99 XJ rear seat back panel that had no stains, frays or damage. Thank God for people who don’t use their cargo area…
Gjeep Posted October 24, 2020 Author Posted October 24, 2020 Chugging along on the XJ... Held my breath once again as I trimmed out a NOS overhead console bezel to fit the hands-free microphone grille I sourced from a '90's BMW (only thing out there that looks like it could belong in an XJ). Then I refinished the panels and let them dry. My goal for tomorrow morning is to get the overhead console re-assembled and up in the Jeep. Also hoping to get the upper trim panels installed!
Gjeep Posted October 25, 2020 Author Posted October 25, 2020 Didn't get as much as I had hoped done with the time I had today, but got the overhead console reassembled, hands-free mic tested, and unit installed in this XJ Sport that didn't come with one from the factory. Additionally, I got about half the upper plastic trim installed -- I had to look high and low to find the 'screw-in' a-pillars in agate color. Ended up buying then selling an auctioned XJ in South Carolina to find these a little over a year ago. This design was only available in very early '99 builds (when the agate interior came out as the gray interior option) and then the a-pillars changed over to the 'clip-in' design which always breaks whenever a-pillar trim is removed. No thanks. As always, getting there one small step at a time... As a side note for any '99+ XJ's with the newer style cargo light -- be sure to remove the purple wire from the connector to the light itself. It took me several melted/ destroyed cargo lamps on my '01 XJ to figure out the factory wiring ran too much current through that light with the on/off push-the-lamp-itself option. Sure I don't have the on/off light capability from the cargo area of the Jeep, but I don't care. I want to save the lamp itself. NOS ones are impossible to come by these days.
Gjeep Posted October 27, 2020 Author Posted October 27, 2020 Happy to say this has been a minimal bleed new carpet install. About 88% done on the front carpet. And have high hopes of getting the cargo area carpet in tomorrow. I can't get into the booth right now to primer the MJ until the 'accident' cars are through, so using this time to close the gap on finishing the XJ.
Gjeep Posted October 29, 2020 Author Posted October 29, 2020 Nearly done with the carpet install. It has taken me a good 2+ full days to get things to look right in the passenger area. ACC is really the only good option for aftermarket replacement carpet. I’ve tried other vendors but haven’t been as happy with the final fit and quality. ACC’s weak point to me, at least on the XJ, is around the trans tunnel. The carpet typically fits like a paper bag. After several carpet installs over the years in both XJ’s/ MJ’s, I’ve learned what works for me is fully opening up the center section of carpet at the transmission tunnel, letting the vehicle idle on/ off for about an hour (heats up the carpet and flattens it out) add-in a mix of heat gun action, and then use zip-ties (like shoestrings) tighten things up for an exact fit. Works every time. I added wiring for the NOS dual power leather seats (available in ‘00/’01 XJ’s only), an inside the center console 12V port, and footwell lights for the rear seat passengers. I always thought that back seat area of the XJ, even with the overhead console lighting was too dark upon entry. I used stock ‘97+ XJ front footwell lights and attached them to the underside of the front seats. I’ve still got the cargo area carpeting to get fitted right and backseat in…then sort out the subwoofer fitment. Getting there.
Gjeep Posted October 29, 2020 Author Posted October 29, 2020 Quick before and almost after pics -- I wasn't a fan of the original saddle/ spice interior color and so began my parts search for agate interior panels. It's not that I dislike saddle, it's just that I think it only looks good on a moss green XJ. (And it looks really good on that color.)
Gjeep Posted November 5, 2020 Author Posted November 5, 2020 Been working between Jeeps odd hours...Got the cargo area carpet in and fit. Took just about as long as getting the passenger area of the carpet in. ACC carpet mats are placed under the Rugged Ridge 'Jeep' logo'd all-weather mats and cargo area tray. These all-weather mats are a nice quality, great fit, and most importantly to me -- cover the hump of the rear passenger area and the entire foot area behind the driver and passenger seats. I'm still waiting on a subwoofer I have on order to finish up that quarter panel area, and at long last found a NOS rear seat belt dual buckles to round out the set. Final touch was the OEM jack instruction label under the rear seat.
89 MJ Posted November 6, 2020 Posted November 6, 2020 Do you want to trade a 13 year old brother for this Jeep by chance?
Gjeep Posted November 11, 2020 Author Posted November 11, 2020 Been getting odds and ends done on the XJ in pockets of time... I disliked the ignition cylinder/ key setup on the ‘97 (and ‘98) XJ from the day I bought it. It looks like an afterthought that visually sticks out too far from the steering column shroud (just a bit under 1/2"). I went with the later ignition cylinder/ key that sits flush to the column shroud. Only minor Dremel-ing needed to happen to get it to fit-- The sides of the newer Mopar cylinder was a pinch wider than the original. A bit surprising. Also took a heat gun to the sub box...This box is a near work of art, but I did make a couple modifications to make it sit as it should in the quarter panel area. The most recent being peeling off the fuzzy carpet on the front side. It’s close to Jeep's agate, but not spot-on. So I scoured many a wrecking yard to find the perfect XJ back of seat carpet to use to recover it. Work in progress... And lastly added a wrecking yard Jeep-sourced power port in the center console.
Gjeep Posted November 12, 2020 Author Posted November 12, 2020 I'm closing in on getting this interior done, though still keeping an eye on the details. I do like the symmetry of the 97+ XJ's dashboard, but it lacks the contrasting color the original XJ dash had. Guess my eyes got use to it and needed to see that familiar appearance. Back when I purchased my '01 XJ new I blacked out areas of the dash and center stack bezel for that contrast... And I'm doing the exact same on this '97. Still need to paint the center stack but got the main overlay done. Also drilled out the plastic weld assembly of the transmission selector to paint and detail this part. Nothing NOS was available, so I renewed the old blacked it out as I did the dashboard inset, and put it back together with factory screws on the bottom-side. And here it is in place. The 4wd shift bezel is where I park my phone for charging while driving.
Gjeep Posted November 20, 2020 Author Posted November 20, 2020 Still chipping away at the XJ -- I went with a TJ aftermarket shifter for the AW4. Also put the Jeep agate carpet surface on the sub box so all matches and refinished the quarter panel interior trim that surrounds the box... The hope is I get this corner of the interior finished this weekend.
Gjeep Posted November 21, 2020 Author Posted November 21, 2020 It's amazing how long things take when you obsess. Finally got the sub setup in place...After carving up the interior panel for fitment, I noticed there was close to 1/2" inch open space that wouldn't look good even with the woofer installed, so I laid down lots of carefully placed rough side velcro I cut strips of the factory agate scraps and placed them fuzzy side up out over the gaps. The rest of the velcro was put in place to stick to the sub box so when the interior panel was re-installed. I wanted the fit to be tight against the enclosure. Finished pics of final installation. Some miscellaneous interior trim still to install, but just about buttoned up.
Pete M Posted November 22, 2020 Posted November 22, 2020 the factory can only dream of getting it that nice
Gjeep Posted November 24, 2020 Author Posted November 24, 2020 Getting down to it -- rear bumper is on and center dash stack in place. Couple more to-do's and the XJ will be good to go!
Red Mistress Posted November 25, 2020 Posted November 25, 2020 Perfection at its finest:) I’ll be doing same rear sub box in daughters 01 XJ. hope I get 10” woofer centered as good !
Gjeep Posted November 26, 2020 Author Posted November 26, 2020 Final touches to the subwoofer install... Once I got the box in and all the interior panels installed, of course first pass at listening to the sub and nada. At first I thought the woofer may have been bad so I tried another sub I had laying around. Still nada. I had a feeling under side of the sub box one of the wires must have come loose from the spring tension connector...Thanks to peek inside space through the lower mounting point of the passenger taillight (removed rubber grommet) I could see in fact BOTH wires came out. I wasn't going to take a part the interior and thankfully the XJ has room to cut back side pocket of the lower quarter panel. So I drilled a 1" hole for my left fingers and a cut-out right side for the right fingers to guide the wiring. Good times. It turns out the way the sub box tension connector was set up it was near impossible NOT to release those wires when fitting the snug box into place. (don't' think flipping it would have helped either -- cutting a notch at the 1/4" raised seam where the cargo floorpan meets the quarter panel sheet metal would have though.) Any way, cut a sheet metal patch, a bit of butyl tape and stainless steel self-tappers and life is good again. Also took some time to cut away the under hood insulation area where the K&N intake setup was rubbing against and leaving a mark. I'm guessing majority of XJ's don't have that insulation, so that reduced height wasn't taken into consideration.
Gjeep Posted December 3, 2020 Author Posted December 3, 2020 Just about done with the '97 XJ... Only thing I'm waiting on is the recovered sun visors. I have an annoying CEL/ rough running issue I've been battling on and off. I need to test the fuel rail pressure because my gut feeling at this point after testing that's got to be the FPR in the flipping tank not functioning properly despite being a new Bosch unit. There are times it seems like its starving for fuel when I hit the accelerator. Easy driving most of the time no issue. When I get on it...CEL and stumbles all over the place.
