youngfred Posted August 25, 2019 Share Posted August 25, 2019 ... Thinking about adding Electric Door Locks. Will these XJ rear-door handle trim with switch, fit the MJ doors? The Actuators are available but I do not know about the rest of the internal hardware. Has anybody added Electric door locks using these? youngfred Link to comment Share on other sites More sharing options...
amsuco Posted August 25, 2019 Share Posted August 25, 2019 I once bought a car that had power door locks and manual windows. I never could understand the logic of that combination. All power? Yes. All manual? Yes. But to have one power and the other manual? No. I'm curious as to what your reasoning is. Link to comment Share on other sites More sharing options...
jdog Posted August 25, 2019 Share Posted August 25, 2019 I just got done swapping windows and locks, I would just do both, the harness needed for the locks is the same, but you could build a harness for just the lock circuit if you wanted. But as stated above why just locks? Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 25, 2019 Share Posted August 25, 2019 I'll have both.........on manual doors. Link to comment Share on other sites More sharing options...
youngfred Posted August 25, 2019 Author Share Posted August 25, 2019 20 minutes ago, amsuco said: I once bought a car that had power door locks and manual windows. I never could understand the logic of that combination. All power? Yes. All manual? Yes. But to have one power and the other manual? No. I'm curious as to what your reasoning is. ... I didn't want to change out door panels(left over-manual window crank hole). My door panels are in great shape. youngfred Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 25, 2019 Share Posted August 25, 2019 2 minutes ago, youngfred said: ... I didn't want to change out door panels(left over-manual window crank hole). My door panels are in great shape. youngfred There are ways to fix that..........crank becomes the switch. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 25, 2019 Share Posted August 25, 2019 Just posting as an example. https://www.ebay.com/p/66-70-Fairlane-Power-Window-Crank-Switch-Kit-2-Doors-AutoLoc-Aut9d6afc-Truck/27021701759?iid=253772095592&chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=253772095592&targetid=475515274701&device=c&mktype=pla&googleloc=9013407&poi=&campaignid=1669934843&mkgroupid=65058350579&rlsatarget=pla-475515274701&abcId=1139296&merchantid=131376560&gclid=CjwKCAjw44jrBRAHEiwAZ9igKBb-naz-ndSFOpx2m7U1HsWmDmN91fe8kyCljd48COx28E49vvn99BoCay4QAvD_BwE Link to comment Share on other sites More sharing options...
youngfred Posted August 25, 2019 Author Share Posted August 25, 2019 ... Quadratec has this one. Each Switch Pod would cover the crank-hole. https://www.quadratec.com/products/73003_801.htm youngfred Link to comment Share on other sites More sharing options...
Minuit Posted August 25, 2019 Share Posted August 25, 2019 There are OEM door switch panels for power locks but no power windows. Not very common, but they do exist. Link to comment Share on other sites More sharing options...
TexanEliminator Posted August 26, 2019 Share Posted August 26, 2019 7 hours ago, youngfred said: ... Quadratec has this one. The Switch Pod would cover the crank-hole. https://www.quadratec.com/products/73003_801.htm youngfred I have searched the net long and hard for some feedback on this kit and can’t find any. I might just be a guinea pig one day and go for it. Link to comment Share on other sites More sharing options...
gogmorgo Posted August 26, 2019 Share Posted August 26, 2019 That kit is for a 2-door XJ. Is it actually going to fit in an MJ that uses the shorter 4-door fronts? Seems odd there's two review, one says it fits great the other said it doesn't fit at all. The "customer photos" are clearly a 2-door XJ. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 26, 2019 Share Posted August 26, 2019 11 minutes ago, gogmorgo said: That kit is for a 2-door XJ. Is it actually going to fit in an MJ that uses the shorter 4-door fronts? Seems odd there's two review, one says it fits great the other said it doesn't fit at all. The "customer photos" are clearly a 2-door XJ. Yep, saw that too. Link to comment Share on other sites More sharing options...
