Plug to radio was cut off by prior owner. Will get a Jeep radio. Anyone have a wiring diagram showing color coded wires that went to radio in an 87 MJ, 4.0, 5 speed?
3 minutes ago, eaglescout526 said:
Send Minuit a Message. He will help you out.
That's the thing. I told him to post here. I don't have the '87 FSM to have definite wire colors. They should be the same as the radio, but without the FSM I can't say that for sure.
You will have-
Ground
Hot (acc)
Memory (always hot).
Dimmer wire (possibly)
Typically-
Black
Red
Yellow
Blue/purple ?
All of which can be verified with a test light in about 2 minutes.
As for speaker wires...........wouldn't even bother, cut them out, run new.
Ground your radio chassis.
