Deleted Posted June 30, 2019 Share Posted June 30, 2019 Just changed my oil (shell Rotella T6 5w-40 for those curious) and when i started it up after i noticed it was dripping a ton from where that little screw is it seems like. Admittedly I'm not sure what this is or why coolant would be leaking out of it, any suggestions? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted June 30, 2019 Share Posted June 30, 2019 Heater valve , because it's bad . Either replace it or run 97+ Cherokee heater hoses and run it without the heater valve Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 2 minutes ago, Strokermjcomanche said: Heater valve , because it's bad . Either replace it or run 97+ Cherokee heater hoses and run it without the heater valve Thats exactly what my dad just told me two seconds ago lol, thank you I'm gonna be removing it entirely Link to comment Share on other sites More sharing options...
Minuit Posted June 30, 2019 Share Posted June 30, 2019 The heater control valve exists to cut flow to the heater core when the temperature control is in the full cold position. The end result is slightly lower cab temperatures (due to there not being a heater core full of hot coolant just behind the dash) and a drop in A/C vent temperatures of as much as 7 degrees Fahrenheit. If you don't have A/C or don't care about a slightly warmer cab, throw the valve in the trash and plug the vacuum line to it. Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 18 minutes ago, Minuit said: The heater control valve exists to cut flow to the heater core when the temperature control is in the full cold position. The end result is slightly lower cab temperatures (due to there not being a heater core full of coolant just behind the dash) and a drop in A/C vent temperatures of as much as 7 degrees Fahrenheit. If you don't have A/C or don't care about a slightly warmer cab, throw the valve in the trash and plug the vacuum line to it. I live in arizona and have no floor insulation so heat is my middle name, I'm gonna chuck it as it brings nothing to the table for me but leaks Link to comment Share on other sites More sharing options...
Ωhm Posted June 30, 2019 Share Posted June 30, 2019 5 minutes ago, Pirate_Staz said: I'm gonna chuck it Don't complain about loss of A/C cooling then. Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 1 minute ago, Ωhm said: Don't complain about loss of A/C cooling then. Ac wasnt very good to begin with, like i said the odds are stacked against me and i end up soaked in sweat when I reach my destination anyway lol Link to comment Share on other sites More sharing options...
Ωhm Posted June 30, 2019 Share Posted June 30, 2019 Your call. Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 30, 2019 Share Posted June 30, 2019 I replaced it with a ball valve in my XJ. Link to comment Share on other sites More sharing options...
Eagle Posted June 30, 2019 Share Posted June 30, 2019 There are mechanical valves you can replace it with. One type can be operated from the cabin with a cable, like a manual choke control. The other type you open or close from under the hood. Open for winter, closed for summer. No big deal. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 30, 2019 Share Posted June 30, 2019 8 minutes ago, Pirate_Staz said: Ac wasnt very good to begin with, like i said the odds are stacked against me and i end up soaked in sweat when I reach my destination anyway lol What?! You have AC? And it’s not working?! I’m jealous that you have AC(I’ll get it soon). Damn, I’d get that fixed in a heart beat if that was me. Chrysler still has those control valves new. But come the winter time, you’ll want that heater core. Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 5 minutes ago, Eagle said: There are mechanical valves you can replace it with. One type can be operated from the cabin with a cable, like a manual choke control. The other type you open or close from under the hood. Open for winter, closed for summer. No big deal. Now that might be a better option Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 4 minutes ago, eaglescout526 said: What?! You have AC? And it’s not working?! I’m jealous that you have AC(I’ll get it soon). Damn, I’d get that fixed in a heart beat if that was me. Chrysler still has those control valves new. But come the winter time, you’ll want that heater core. It doesnt work very well, no tint, the flooring and trans housing has no insulation, the windows don't seal perfectly, A/C on isnt much different from A/C off. I didnt buy an MJ for the comfortability, otherwise i woulda kept my tacoma lol. Edit: to add to this, i have no boot on my shifter so tons of heat just comes out of that hole on the trans tunnel Link to comment Share on other sites More sharing options...
Ωhm Posted June 30, 2019 Share Posted June 30, 2019 Maybe the heater core bypass valve is stuck open. Does the lever move between HEAT and A/C modes? Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 Just now, Ωhm said: Maybe the heater core bypass valve is stuck open. Does the lever move between HEAT and A/C modes? Ill have to check, good question Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 30, 2019 Share Posted June 30, 2019 Which boot don’t you have? The console boot or the floor boot? Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 13 minutes ago, Eagle said: There are mechanical valves you can replace it with. One type can be operated from the cabin with a cable, like a manual choke control. The other type you open or close from under the hood. Open for winter, closed for summer. No big deal. Is this what youre talking about? Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 Just now, eaglescout526 said: Which boot don’t you have? The console boot or the floor boot? Both, literally just metal flooring and a bench seat in there. The floor boot is ripped Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 30, 2019 Share Posted June 30, 2019 1 minute ago, Pirate_Staz said: Both, literally just metal flooring and a bench seat in there. The floor boot is ripped I believe JMO found an acceptable Chrysler replacement floor boot for the TJ he made fit. I’m sure there’s aftermarket console boots. But those boots will help a little with the heat but if there’s no insulation under that carpet, yeah you are kinda hosed with heat. Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 Just now, eaglescout526 said: I believe JMO found an acceptable Chrysler replacement floor boot for the TJ he made fit. I’m sure there’s aftermarket console boots. But those boots will help a little with the heat but if there’s no insulation under that carpet, yeah you are kinda hosed with heat. I don't even have carpet either, I'm bare bones over here haha Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 30, 2019 Share Posted June 30, 2019 Oh boy. Alight. Chalk that up for two MJs in AZ that are portable toaster ovens. Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 1 minute ago, eaglescout526 said: Oh boy. Alight. Chalk that up for two MJs in AZ that are portable toaster ovens. here's an older pic, only thing thats changed is that its much cleaner now. But yea AC doesnt really matter when youre getting cooked alive from the floor. Ive tried looking for upholstery places to get some insulation and carpet but everyone acts like I'm crazy for suggesting it or something. Guess ill have to do it myself eventually Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 30, 2019 Share Posted June 30, 2019 Insulation shouldn't be a problem to cut and put in yourself. Plenty of DIYs and ideas for that. I think the original vendor for the MJ carpet still makes carpet for our trucks. Someone may have the link to them. Anyways this thread got way off track. Link to comment Share on other sites More sharing options...
Deleted Posted June 30, 2019 Author Share Posted June 30, 2019 Just now, eaglescout526 said: Insulation shouldn't be a problem to cut and put in yourself. Plenty of DIYs and ideas for that. I think the original vendor for the MJ carpet still makes carpet for our trucks. Someone may have the link to them. Anyways this thread got way off track. Yup, i think I'm gonna go with eagles idea and put a manual mechanical one in that way i can still have heat and A/C but also don't have to worry about it failing on me or restricting flow Link to comment Share on other sites More sharing options...
Eagle Posted June 30, 2019 Share Posted June 30, 2019 1 hour ago, Pirate_Staz said: Is this what youre talking about? That's it. If you don't want to bother with the cable, just install it and open or close it from under the hood when the season changes. That valve was the factory heater valve in all AMC cars in the 1960s and 1970s. It's variable volume, so with the cable that's what controlled the amount of heat you got. Full open ==> full heat. Throttle it back for less flow to produce less heat. Link to comment Share on other sites More sharing options...
