cocco78 Posted September 15, 2007 Posted September 15, 2007 What are some of the things to check for gas in the oil. The truck runs just fine, but after running it on a few 100 mile trips I went to check the oil and it was way above the full mark and smelled like gas. Like I said the truck runs real well, and doesn't overheat or anything... Its also got newer ford motorsports 19# injectors, but it did the same thing with the old injectors. Any idea's?
mfpdm Posted September 16, 2007 Posted September 16, 2007 I've heard gas in the oil is very dangerous and could cause a explosion or fire. :eek: Or is this just some urban legend? :dunno:
CWLONGSHOT Posted September 16, 2007 Posted September 16, 2007 Sorry to say your engine is on borrowed time...gas is one of the poorest lubricators... breaks down the oil until its not worth Dukie. :roll: Dukie = technical term meaning CRAP!! :D :D Sorry its been a long day!! CW
Eagle Posted September 16, 2007 Posted September 16, 2007 I've heard gas in the oil is very dangerous and could cause a explosion or fire. :eek: Or is this just some urban legend? :dunno: Not urban legend. Bad ju-ju.
cromanyak Posted September 16, 2007 Posted September 16, 2007 If you start your vehicle alot without letting the motor heat up you can get gas in your oil. I had the same problem with my Nissan 300ZX.
cocco78 Posted September 16, 2007 Author Posted September 16, 2007 I don't believe its blowby, wouldn't the motor have poor compression then? Its not like a little gas, it read a good 2 inches past the full mark on the dipstick...
Eagle Posted September 16, 2007 Posted September 16, 2007 This happened to me once with a 1939 Hudson I was restoring -- but that had a mechanical fuel pump on the block and the internal diaphragm ruptured. I can't think of any way that much gasoline could get by the rings in a fuel injected system, unless the injectors aren't functioning right and the system is pumping way too much fuel. How old is the oxygen sensor? Have you had the truck scanned to see what kind of readings the O2 sensor is sending to the ECU? The only thing I can think is that it's running in open loop mode and sending too much fuel, all the time. It isn't safe to drive it that way. Get it checked.
DirtyComanche Posted September 17, 2007 Posted September 17, 2007 I don't believe its blowby, wouldn't the motor have poor compression then? Its not like a little gas, it read a good 2 inches past the full mark on the dipstick... You did a compression check? Does it fire on all cylinders? Pull the plugs and see if they're wet. If it doesn't, that can cause problems. I've seen engines with the oil level creep up due to blow-by. Not as bad though. Anyways, the PCV system is supposed to burn off all that crap, but that never really happens. Not that it would account for that much. FWIW, despite gas being really useless for the oil, I bet the motor will be okay for quite a while. These things seem to be tough enough...
FxRacing282 Posted September 17, 2007 Posted September 17, 2007 o2 sensor is on the exhaust pipe so thats out the question. as for compression if you have a warped cylinder yes gas can leak but it would obviously still rin just on like 5 3/4 cylinders. so id go to nape or grab a compression checker and check compression on all your cylinders. also check the vacume/breather that comes off the block and see if gas iis going in there. hopefully its not a vavle :headpop:
cocco78 Posted September 18, 2007 Author Posted September 18, 2007 I checked the compression a while back when we first got the truck, it was pretty good, I can't remember the numbers. And its firing on all 6, it runs great and has plenty of power.... i'm going to recheck the compression but I don't think thats the problem.
JeepcoMJ Posted September 18, 2007 Posted September 18, 2007 good idea. but remember, you're running a time bomb there...gas plus oil plus heat plus friction plus compression....you add more air in there, and you've got one hell of a bonfire. so as eagle has stated, it is NOT safe to drive
FxRacing282 Posted September 18, 2007 Posted September 18, 2007 i would still check the compression as of now and not rely on numbers that are getting old.
Eagle Posted September 18, 2007 Posted September 18, 2007 o2 sensor is on the exhaust pipe so thats out the question. Out of the question? Are you joking? The O2 sensor is the sensor that reads the percentage of unburned hydrocarbon in the exhaust and controls the amount of fuel the injectors squirt. A dead O2 sensor results in an engine that runs super-rich, all the time. I'd say that's FAR from being out of the question. It is, in fact, a very likely suspect.
FxRacing282 Posted September 18, 2007 Posted September 18, 2007 right but he is complaining about gas in the oil. not gas in the exhaust.
JeepcoMJ Posted September 18, 2007 Posted September 18, 2007 uh...fx... the o2 sensor helps input CONTROLS to the fuel system. if it is reading WRONG then you better believe that he's running rich. re-read the previous statement to yours, it should make sense because he is 100% spot on right.
87manche Posted September 18, 2007 Posted September 18, 2007 uh...fx... the o2 sensor helps input CONTROLS to the fuel system. if it is reading WRONG then you better believe that he's running rich. re-read the previous statement to yours, it should make sense because he is 100% spot on right. he is indeed correct. I would also cheack that you've not got an injector that's stuck open. A stuck injector would allow a lot of gas into the cylinder, even when the motor was off. Pull the spark plugs, and look to see if one looks a lot different than the other.
FxRacing282 Posted September 18, 2007 Posted September 18, 2007 so how would running rich make fuel go in the oil?
JeepcoMJ Posted September 18, 2007 Posted September 18, 2007 too much fuel would mean it's pushing fuel into the exhaust valves, or too much fuel could also cause more blowby past the rings if the rings are already somewhat bad. too much fuel kinda f*ks things up. it makes sense, trust me.
FxRacing282 Posted September 18, 2007 Posted September 18, 2007 hmm if its pushing into the exhaust vavle it would go into the enhaust... so then it would most likely be blowby whcih could be caused from a normal amount of gas going through.
Pete M Posted September 19, 2007 Posted September 19, 2007 I'm leaning towards the "stuck open injector" theory. I can't imagine that even a engine running balls-outs rich all the time could push that much gasoline into the crankcase. :eek: I'm super curious to find out what the problem is.
cocco78 Posted September 19, 2007 Author Posted September 19, 2007 There is no fuel going into the exhaust, I know that much. As far as the injectors go, there is no change from the original injectors to the new ford motorsports 19# injectors we put in. Also, I've had 02 sensors go bad and it created a very bad problem with the motor running rich, which in turned cause it to run poorly and created alot of smoke through the exhaust. i'm still putting in a new sensor tho as its cheap enough and a good idea as they gradually loolse performance. At this point its all purely speculation as I don't have time to check it out. But the truck runs good, does not have smoke from the exhaust, and doesn't exhibit any characteristics of running rich. So just from that info, what does that leave? 1. After its shut off the presurized fuel from the fuel rail leaks into the cylinders and gets past the rings into the crankcase 2. Fuel is entering the crankcase while it is running from somewhere else, ie the vacuum system 3. There is just enough blow by in the rings to let fuel by but not oil into the combustion chamber. Anything else?? Once I have time to start actually looking at the truck i'll be sure to post my findings. First thing would be a compression test, then I guess a leak down test of the fuel preasure in the rail....[/b]
JeepcoMJ Posted September 19, 2007 Posted September 19, 2007 sorry, I meant to say intake valve but really either...if it somehow got up in the valve cover, it would fill the crank case. anywho, I really do hope you don't drive it. I don't wanna see you 'splode any time soon
