Duh, what is ...
Curious about the name of the part that bolts/connects to the Ford 8.8 axle and the jeep driveshaft.
The picture shows the 4 bolts. I tried to get the piece in question but had difficulty in removing it.
Thank you.
Companion flange.
The other flange (on your axle) is the pinion flange...  So the one that goes with it is the companion.
But you will hear adapter flange too...
Ford glues the ujoints in so they're rather terrible to get out.  The Explorer would have the tight size.  Hacksawing the driveshaft is easier if you're at a pick and pull type place.
Oh that makes sense. The glue part. No wonder I couldn't get it apart.
