JMO413 Posted June 1, 2019 Posted June 1, 2019 Any one like their VIN decoded? At home with the computer on. Let me know
13 Legion Posted June 1, 2019 Posted June 1, 2019 Have we ( you or Eagle!)figured out who has the earliest build date and the last build date?
JMO413 Posted June 1, 2019 Author Posted June 1, 2019 I have no idea. I just copied and pasted the build sheets. I had to type in the body model and build dates. The only build date I can remember is 8/8/88. I was doing it on dual screens at work during dead time. Was fun to see all the pictures though.
Eagle Posted June 1, 2019 Posted June 1, 2019 1 hour ago, 13 Legion said: Have we ( you or Eagle!)figured out who has the earliest build date and the last build date? They're gone now, but I've owned very early example of both the XJ and MJ. I rescued them from oblivion, and eventually passed them along to brethren from NAXJA. The XJ was a very early '84 XJ Wagoneer. I've had two '86 MJs, one of which was rescued from a scrap yard. All of the early ones I had were four-bangers. The reason I think at least one of the '86 MJs was very early is that there was something (which I don't remember now) that was different about the rear suspension than any other MJ I've ever seen. Production changes are often a clue. I encountered the same thing with AMC Javelins. The one I bought new (1968 production) had staggered rear shocks, to combat axle hop over bumps. I later picked up another, 1967 production, on which both shocks came down behind the rear axle. It did make a difference.
eaglescout526 Posted June 2, 2019 Posted June 2, 2019 2 hours ago, 13 Legion said: Have we ( you or Eagle!)figured out who has the earliest build date and the last build date? The earliest build date I found in '86 was 8/5/85 if I remember correctly. I just returned home from vacation so I'm going to work on all this stuff and finish up the '88 registry. I may be on to something as far as trim levels with the body codes that JMO posted,
MJXJjeepguy Posted June 2, 2019 Posted June 2, 2019 13 minutes ago, eaglescout526 said: The earliest build date I found in '86 was 8/5/85 if I remember correctly. I just returned home from vacation so I'm going to work on all this stuff and finish up the '88 registry. I may be on to something as far as trim levels with the body codes that JMO posted, I wonder what the latest build u have seen?
eaglescout526 Posted June 2, 2019 Posted June 2, 2019 I did not touch ‘92 sadly. My best guess would be either may or June for the last production as I noticed that new model years began on July and ended in June of that model year.
JMO413 Posted June 2, 2019 Author Posted June 2, 2019 1J7FT66S0NL248684 is the youngest MJ in the registry 5/3/92
eaglescout526 Posted June 2, 2019 Posted June 2, 2019 So it looks like May is when they were finishing up.
gogmorgo Posted June 2, 2019 Posted June 2, 2019 On June 1, 2019 at 4:37 PM, 13 Legion said: Have we ( you or Eagle!)figured out who has the earliest build date and the last build date? 22 hours ago, eaglescout526 said: The earliest build date I found in '86 was 8/5/85 if I remember correctly. I just returned home from vacation so I'm going to work on all this stuff and finish up the '88 registry. I may be on to something as far as trim levels with the body codes that JMO posted, Earliest I found in the registry is 7/6/85
