Pete M Posted May 15, 2019 Posted May 15, 2019 So it's been a while now since I had the idea of adding "tags" and haven't been able to find the time to do it myself and then I learned that regular members couldn't add tags to threads like admins can so I couldn't farm it out... so I've come up with a plan C: see if one or more of you guys would like to skim through the Epic tech threads and jot down the highlights of the projects in a way that I can then use your notes to add in "tags" that help people know what's inside said threads (V8, turbo, 1-ton axles, whatever it is that makes it special). Sound like something anyone would like to do?
JMO413 Posted May 15, 2019 Posted May 15, 2019 I would be down to read some epic builds. I've been reading through the regulars lately. Plan on who should start where? Or where I should start?
Pete M Posted May 16, 2019 Author Posted May 16, 2019 so far you're a one man band, so you can start wherever you'd like if others chime in, then we can get more organized. Just looking for maybe the 3-5 best mods, focusing on the things that got them in Epic Tech in the first place (like a 5.3L v8 swap, turbo 4.0L, Exocage, etc). don't worry about making a huge list of all the mods for each truck. If the Epic threads go well and we get more help, we can certainly expand to do all the project threads
IronManche87 Posted May 16, 2019 Posted May 16, 2019 I can put in some time this weekend if it helps Sent from my LM-Q610(FGN) using Tapatalk
Pete M Posted May 16, 2019 Author Posted May 16, 2019 5 hours ago, IronManche87 said: I can put in some time this weekend if it helps Sent from my LM-Q610(FGN) using Tapatalk go for it maybe start at the oldest one?
JMO413 Posted May 16, 2019 Posted May 16, 2019 IRS- independent rear suspension IFS- independent front suspension Lowered Not sure what you would label a one off front crossmember. I'm going to start in the newest. I have been following this already.
eaglescout526 Posted May 16, 2019 Posted May 16, 2019 Damn. I want to help but my computer is down and reading everything on the phone is not fun. As soon as I get my computer back up I’ll get right on it if we have not finished. (PS, don’t install preview build 1903 if you have windows insider)
JMO413 Posted May 17, 2019 Posted May 17, 2019 Front/rear Dana 44 locked 4.88 10" lift T-case doubler 37"-40" tires Lots of pictures!
JMO413 Posted May 17, 2019 Posted May 17, 2019 V8 350 700R4 Custom gauges Holley sniper fuel injection DUI HEI distributor
JMO413 Posted May 17, 2019 Posted May 17, 2019 97+ conversion 3 link 2 low Aux fuse box Dana 44's frt & rear
JMO413 Posted May 17, 2019 Posted May 17, 2019 97+ conversion Clayton Long Arm front Fabricated bumper 350 Vortec/TH350/241C King coil over Custom gauges 4 link rear Rock sliders
JMO413 Posted May 17, 2019 Posted May 17, 2019 Short throw shifter homemade Lowered Custom front axle 97+ washer tank WJ knuckles 96 XJ booster
IronManche87 Posted May 18, 2019 Posted May 18, 2019 https://comancheclub.com/topic/6472-400sbc-in-the-jeep/ 400ci chevy swap 4linked Custom gauge cluster Sent from my LM-Q610(FGN) using Tapatalk
IronManche87 Posted May 18, 2019 Posted May 18, 2019 Wow.. Second build in and I can't believe what I stumbled across.. https://comancheclub.com/topic/14435-87-mj-lifted-y-linked-n-more-to-come/page/3/I'll start with the build sheet first.CagedStrokerLong armed97 swapped 4.0l and interiorNow for my discovery.. That red truck that they picked up at the junkyard? I noticed the interior looked exactly like mine did then seen the plates and it IS my truck!! I had lost Brandon's number shortly after buying it a couple years ago (broke my phone) and never got the chance to ask if he was one here but turns out he is lol I am beyond stoked! Just for reference this is the red truck now Sent from my LM-Q610(FGN) using Tapatalk
IronManche87 Posted May 18, 2019 Posted May 18, 2019 https://comancheclub.com/topic/12473-comanche-turned-truggy/TruggyTonsCaged4linked Sent from my LM-Q610(FGN) using Tapatalk
IronManche87 Posted May 18, 2019 Posted May 18, 2019 https://comancheclub.com/topic/18014-and-it-begins/Bobbed bedCustom taillightsCustom front bumperSent from my LM-Q610(FGN) using Tapatalk
Pete M Posted May 18, 2019 Author Posted May 18, 2019 8 hours ago, IronManche87 said: Now for my discovery.. That red truck that they picked up at the junkyard? I noticed the interior looked exactly like mine did then seen the plates and it IS my truck!! wow!
JMO413 Posted May 18, 2019 Posted May 18, 2019 6.0. LS2 4L70E Atlas 4 t-case Long Arm front 4 link rear 97+ conversion Bead locks Fuel cell PRP seats
JMO413 Posted May 18, 2019 Posted May 18, 2019 6.0 LS 4L65 Atlas twin stick 5.38's spool/ locker On board air Air horn Custom gauges Exo cage
JMO413 Posted May 18, 2019 Posted May 18, 2019 5.3 4L60 231 97+ conversion Clayton Long arms JK Dana 44's Frame stiffners JCR bumpers 37 x12.50x17 Notch flares
JMO413 Posted May 18, 2019 Posted May 18, 2019 Videos OM617 Diesel swap Custom gauges Fabricated bed A-Piller Gauge pod 97+ conversion 8.8
