1972 Bolens Husky 1556
  • Replies 95
I  bought a brand new starter solenoid for my snow blower tractor, installed it, cranked the engine over, all seemed good. I went to clear snow with it 2 days later and the brand new starter solenoid had failed. :fistshake2:
6 minutes ago, MiNi Beast said:
darn i say "china" :sad2:
6 minutes ago, Jesse J said:
chinesium is the weakest materiel known to man
I'm sure it was Chinese BS, but it was the only one they had in stock.
I installed a different starter solenoid, and it is still not cranking. I will need to do some more digging a different day. I am assuming either this new starter solenoid (different brand before) is also bad, I must have broke a wire when I was hooking stuff back up. :dunno:
3 hours ago, MiNi Beast said:
better check the fuse/fuselink as well.
check the starter with battery direct or take it back to auto store to run a test on it.
Thanks. I think my issue was that I didn’t have the parking brake set. :dunce:
  • 1 month later...
A fuel pump went out in one of the tractors. I replaced it with another OEM one that I had, but it leaks, so a fuel pump rebuild is coming soon. And I think they both are leaking hydraulic fluid.
Hmmmmm, I have a very nice tractor that doesn't run great, an ok tractor that runs great, and an extra 4.0 that I need to put a new crank in. Anyone want to see me 4.0 swap one of these (the less nice one) come spring or summer?
  • 2 months later...
Did the old swaparoo from winter to spring by putting the tiller on the nicer tractor. They both were parked for a few months and fired right up.
  • 1 month later...
Well, I sold the less-nice tractor today. I really didn’t need it. It was nice to have when we were doing some projects, but we don’t do a ton of projects where we need two.
  • 2 months later...
  • 2 years later...
