Factory push bar ?
9 hours ago, krustyballer16 said:
That is an aftermarket one. Generic fit all push bar. It's not contoured to fit the jeep bumper exactly like this...2135e7e6719cb38a5fe3293f118caf2b.jpg
Sent from my SM-G892A using Tapatalk
Can you post some pics of what that is mounted to? And how?
Is it bolted to the factory tow hook brackets?
Mine is very similar. My bracket are welded on and face to the inside. There are four bolts that hold it to the factory bumper bar.IMG_20190210_201501593.jpg.2586016ff1170045db910dc7c1143ef6.jpg
This is the to bolt. The fog light almost hides it.
You can sorta see the mount tab in this one.
Last two pictures are the bottom mount tabs. Hope this helps.
So were the OE ones only attached to the thin sheet metal bumper without any additional bracing? I mean I know the factory stuff is almost just decorative due to needing to survive crash testing, but that doesn't seem very solid at all.
