Submariner Posted January 15, 2019 Share Posted January 15, 2019 OK, my wiper has a bump, thump, or knock. as the motor goes round the arm is loose in it connection at the piece that goes to each wiper . there is a plastic piece that slips over the ball joint of the arm. It is worn to the point that is has about a 1/16" play. just enough to be annoying, hence the bump, thump, or knock. Does any one know where or if I can procure three of these. probable should get 6 cause not only does my comanche have this problem but also my 97 cheorkee. same part. It is the black piece in the middle picture. the first picture is the wipper motor and arm. Any ideas? Thanks Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 15, 2019 Share Posted January 15, 2019 This might help. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 15, 2019 Share Posted January 15, 2019 And while you have the wiper assembly out, take the motor apart. Clean out the dried and hard lube in there. Use a Moly grease inside. Find the ground wire and add another wire to it and run that over under the Torx bolt that holds the pivots in. Link to comment Share on other sites More sharing options...
coolwind57 Posted January 16, 2019 Share Posted January 16, 2019 Funny seeing this. I'm getting ready to do this very job this weekend. Got my bushings in today. Upgrading to the 97+ wiper arms too. Picked up a used pair on Ebay earlier. My local Pull-A-Part is not doing XJ/MJ these days. Used to have 12-15. Now only one 2001 XJ on the lot. Good reminder, cruiser54. Thanks. Link to comment Share on other sites More sharing options...
Pete M Posted January 16, 2019 Share Posted January 16, 2019 they are getting harder to find in pullapart junkyards when to a couple big yards today and saw all of 2 XJs. Link to comment Share on other sites More sharing options...
Submariner Posted January 16, 2019 Author Share Posted January 16, 2019 going to be that you need to buy a broke one to have in the back yard for parts. I am going to the next swap meet. http://www.moonshinersjeepclub.com/swapmeet/swapmeet.htm Link to comment Share on other sites More sharing options...
