Swampy Posted January 8, 2019 Share Posted January 8, 2019 Hey guys looking for some 2.5l or (if I can retrofit some renix 4.0l) power steering equipment. I am looking for everything preferably, but will consider just the pump, hoses, and fluid reservoir. If anyone has one, or has leads about one, please contact me Link to comment Share on other sites More sharing options...
MeanLemons Posted January 8, 2019 Share Posted January 8, 2019 1 hour ago, Swampy said: Hey guys looking for some 2.5l or (if I can retrofit some renix 4.0l) power steering equipment. I am looking for everything preferably, but will consider just the pump, hoses, and fluid reservoir. If anyone has one, or has leads about one, please contact me I have a renix 4.0L pump, reservoir and hoses I pulled off my 88. Link to comment Share on other sites More sharing options...
Swampy Posted January 9, 2019 Author Share Posted January 9, 2019 7 hours ago, saveevryjp1998 said: Which 2.5 setup? renix tbi 2.5. Walt told me I could fit a 4.0l pump Link to comment Share on other sites More sharing options...
Swampy Posted January 10, 2019 Author Share Posted January 10, 2019 13 hours ago, saveevryjp1998 said: I'm unsure of that but I think about anything is adaptable if your up to the task. My ? For which setup up was more for pulley style. There were several 86 belt routing setups with at least 2 pulley styles. I have both and 1 seems much harder to find the pulley. I also believe the pumps are the same but again with slightly different clocking orientations. The pumps are rebuildable and you can get them at the box stores but you need the right 1. I think I have come across them swapped with wrong pumps since they are sitting at about the 3-4 o-clock position leaning to far to the right. With my jeep being away from me at the moment. This is the best picture I got to show the belt routing I know its not great. I will try to draw it and get it uploaded tomorrow Link to comment Share on other sites More sharing options...
MeanLemons Posted January 10, 2019 Share Posted January 10, 2019 Well if u want to try a renix 4.0 pump and stuff. Let me know Link to comment Share on other sites More sharing options...
Swampy Posted January 10, 2019 Author Share Posted January 10, 2019 1 hour ago, MeanLemons said: Well if u want to try a renix 4.0 pump and stuff. Let me know Is it a 3 bolt system? Can you post some pics? Link to comment Share on other sites More sharing options...
MeanLemons Posted January 10, 2019 Share Posted January 10, 2019 50 minutes ago, Swampy said: Is it a 3 bolt system? Can you post some pics? Link to comment Share on other sites More sharing options...
carnuck Posted January 14, 2019 Share Posted January 14, 2019 (edited) When I put that style on my ‘87 4 cyl, I had to space it all forward about 3/8” (10mm) for the serpentine pulleys to line up and the reservoir to clear the exhaust. It originally had the one with a remote reservoir but it came loose on the previous owner and destroyed the serpentine pulley. Edited January 14, 2019 by carnuck Clarification Link to comment Share on other sites More sharing options...
Swampy Posted January 15, 2019 Author Share Posted January 15, 2019 6 hours ago, carnuck said: When I put that style on my ‘87 4 cyl, I had to space it all forward about 3/8” (10mm) for the serpentine pulleys to line up and the reservoir to clear the exhaust. It originally had the one with a remote reservoir but it came loose on the previous owner and destroyed the serpentine pulley. I can deal with the spacing out part, if it worked was my main concern Link to comment Share on other sites More sharing options...
Swampy Posted January 15, 2019 Author Share Posted January 15, 2019 On 1/9/2019 at 11:37 PM, MeanLemons said: How much for the set up? Link to comment Share on other sites More sharing options...
MeanLemons Posted January 15, 2019 Share Posted January 15, 2019 You are welcome to make an offer on it. Link to comment Share on other sites More sharing options...
mjtjnj Posted January 29, 2019 Share Posted January 29, 2019 I have a brand new Chryco pump for 2.5 from my 87 serpentine belt setup. Still have the box. Was installed once, and removed. Had a power steering issue that turned out not to be the pump. Can send pics if interested. Link to comment Share on other sites More sharing options...
Submariner Posted February 14, 2019 Share Posted February 14, 2019 Did you find what you are looking for? I just bought a 86MJ with a 2.5 that I am going to salvage Link to comment Share on other sites More sharing options...
Jeep Driver Posted February 15, 2019 Share Posted February 15, 2019 On 2/13/2019 at 9:18 PM, Submariner said: Did you find what you are looking for? I just bought a 86MJ with a 2.5 that I am going to salvage Assuming you have the serpentine belt. He can use any pump, self contained reservoir or remote, does not matter, on up through 2004 WJ. What is crucial to the Renix era 2.5 is the pulley, it is different from the 4.0. Whether Swampy takes it or not..........make sure that pulley gets to someone who needs it. Hard to find. Link to comment Share on other sites More sharing options...
Submariner Posted February 15, 2019 Share Posted February 15, 2019 I wll see if I can get a better picture today. Link to comment Share on other sites More sharing options...
Submariner Posted February 15, 2019 Share Posted February 15, 2019 no serpintine belt Link to comment Share on other sites More sharing options...
carnuck Posted February 15, 2019 Share Posted February 15, 2019 I still have a great dislike for the Vee belt system. Especially when the alternator bracket doesn’t have the AC brace from above. So many of those broke over the years and I had at least one fall forward and eat the radiator with no warning. Link to comment Share on other sites More sharing options...
Submariner Posted February 16, 2019 Share Posted February 16, 2019 here is a picture looking down at what looks like a shock attached to the alternator bracket. and pictures of ps unit Link to comment Share on other sites More sharing options...
Submariner Posted February 17, 2019 Share Posted February 17, 2019 pulled the front off the comanche and here is what I found. I am parting this one out. Link to comment Share on other sites More sharing options...
Swampy Posted February 19, 2019 Author Share Posted February 19, 2019 Thanks for all the help guys. I got a full power steering setup from a member here out of a 4.0l mj. Should arrive at my house by Wednesday. Link to comment Share on other sites More sharing options...
