omega_rugal Posted December 5, 2018 Share Posted December 5, 2018 so the last weekend i took the mj to do some chores, it worked fine as usual and was parked for the las 3 days. this afternoon i try to turn it on but the starter is too heavy, my first diagnostic was that the battery was discharged (i may have left something on) tried another know-to-be-good battery but nopé, same thing, it tries to hard to start then it catches up and runs, next step is drop the starter to see what´s wrong but, how does this happen? can the started run fine and then $#!& on you next day? Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 5, 2018 Share Posted December 5, 2018 Loose wire or bad wire. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 5, 2018 Share Posted December 5, 2018 How much oil is coating that starter? Link to comment Share on other sites More sharing options...
grumpiebill Posted December 5, 2018 Share Posted December 5, 2018 so the last weekend i took the mj to do some chores, it worked fine as usual and was parked for the las 3 days. this afternoon i try to turn it on but the starter is too heavy, my first diagnostic was that the battery was discharged (i may have left something on) tried another know-to-be-good battery but nopé, same thing, it tries to hard to start then it catches up and runs, next step is drop the starter to see what´s wrong but, how does this happen? can the started run fine and then $#!& on you next day? This isn't unusual. Can you jump the starter solenoid to see if it cranks okay that way? Or remove and bench test?Sent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
Minuit Posted December 5, 2018 Share Posted December 5, 2018 When this happens gradually, it's usually because of crud from 30 years of oil leaks getting inside the starter. If it happened suddenly I'd be looking at the connections first. Refresh the connections at the starter and battery and check voltage at the starter when cranking. Link to comment Share on other sites More sharing options...
gogmorgo Posted December 5, 2018 Share Posted December 5, 2018 X2 on poor connections. Starters do slow down over time, but usually they either work or they don't. I've had bad connections "out of the blue" pretty frequently. Recently about an hour into a road trip I pulled over to take a photo and then couldn't start it. Everything looked mostly fine, but all I got was a whirr-clunck then just the relay clicking. Someone else pulled off and I asked for a boost but it didn't help. We ended up bump starting it on a tow strap. I figured it was the starter so I drove straight to a parts store, but first I picked up one of the penci-sharpener style terminal cleaners, and went to town. The problem hasn't recurred. I also once had a no-crank no-boost in a hotel parking caused by a loose starter cable. Somehow the nut that held it onto the solenoid had backed halfway off. It had worked fine the rest of the trip and wasn't loose like it had just jiggled itself off, and didn't look recent either, so I don't know what's up with that. Link to comment Share on other sites More sharing options...
omega_rugal Posted December 5, 2018 Author Share Posted December 5, 2018 1 hour ago, cruiser54 said: How much oil is coating that starter? like, a lot... all conections have been checked, no loose wires, the only way to get it to crank as before is connecting the 2 batteries together... i had a similar problem years ago with a ford escort, starter failed overnight, turned out to be worn carbon brushes... i´ll drop the starter next saturday... Link to comment Share on other sites More sharing options...
cruiser54 Posted December 6, 2018 Share Posted December 6, 2018 That's likely the culprit. Got a spare starter or a new or rebuilt one? If not, take yours apart and clean it out with brake cleaner. It comes apart easily. Fix your oil leak. Link to comment Share on other sites More sharing options...
omega_rugal Posted December 8, 2018 Author Share Posted December 8, 2018 is done, it was all wet and dirty inside... it´s been cold and damp lately, water must have condensated inside with no way to go out... Link to comment Share on other sites More sharing options...
cruiser54 Posted December 11, 2018 Share Posted December 11, 2018 So, it's working now? Link to comment Share on other sites More sharing options...
omega_rugal Posted December 12, 2018 Author Share Posted December 12, 2018 yes Link to comment Share on other sites More sharing options...
