olddude Posted November 6, 2018 Posted November 6, 2018 4.0 2WD SWB AT w/overdrive Bucket Seats Tilt Steering Wheel The Truck is practically stock except for a few improvements. Step bumper, Aluminum recovery tank(cooling system), 1999 Cherokee windshield which replaces the metal trim with a wrap around rubber seal, and Re-upholstered seats. 217,500+ miles driven almost daily build date 1/8, I bought the truck new almost 30 years ago. I have changed the oil every 3,000 miles and use nothing but Castrol. I don't have a picture, will have to make some but I thought you all might enjoy the window stick from 1989 89 Comanche.pdf
olddude Posted November 6, 2018 Author Posted November 6, 2018 I forgot to add location, Greensboro, GA
JMO413 Posted November 7, 2018 Posted November 7, 2018 That window sticker is cool! I would take a new one for $12000.
olddude Posted November 11, 2018 Author Posted November 11, 2018 Okay, I finally have a clear day to take a few photo's. My truck needs a bath and I make no claim of being a photographer but here goes.
olddude Posted November 11, 2018 Author Posted November 11, 2018 Note the 99 XJ windshield in the third pix, rubber seal fits great and keeps water from getting to frame. Also, in last pix aluminum recovery tank.
JMO413 Posted May 30, 2019 Posted May 30, 2019 *B1 TRIM STYLE B1 - CLOTH && VNL BENCH SEAT -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF American Coin Merchandising 4HC Special Scheduling Condition III 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JGB Digital Clock JJA Cigar Lighter JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KWW T: BRILLIANT WHITE - NAMEPLATES - W LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA 19 SPKRS SRT High Perf Audio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Body model TL62 Build Date 1/27/89
fiatslug87 Posted June 24, 2020 Posted June 24, 2020 @olddude can you post a picture of the driver's side so I can see the gas door placement? You say this is a SWB but the VIN comes back as a LWB. Thanks.
jdog Posted June 24, 2020 Posted June 24, 2020 vins not correct correct vin is 1J7FT36L9KL525478 with that vin body code: tm61 build date 1/27/89 APAS-Monotone Paint BGAS-Power Front Disc/Rear Drum Brakes BJAS-DESCRIPTION NOT AVAILABLE BKPS-10x2.5 Rear Drum Brakes CKAS-Carpets - Floor and Cargo Area CSRS-Passenger Assist Handles DGSS-4-Speed Automatic AW4 Transmission DHAS-Lock-Up Torque Converter DMDS-3.55 Rear Axle Ratio DRJS-175MM Rear Axle GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GNAS-Rear View Day/Night Mirror JAAS-Instrument Panel JBDS-Instrument Panel Satin Silver Bezel JCAS-85 MPH Primary Speedometer JJAS-Cigar Lighter JKBS- KKES-DESCRIPTION NOT AVAILABLE K2XS-STRIPE/BADGE/MOLDING/COLOR K3AS-STRIPE/BADGE/MOLDING/COLOR LAFS-Seat Belt Alert-Driver Seat only LBCS-Glove Box Lamp LCJS-Overhead Ambient Surround Lighting LMAS-Halogen Headlamps MBJS-Black Front Bumper MB1S-Black Front Bumper MFGS-Body Color Headlamp Bezels MHAS-Black Windshield Moldings MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings MMKS-Lower Grille Surround-Painted Silver NAAS-Federal Emissions NBAS-Underground Calibration NBKS-EVAP Control System NDAS-Catalytic Converter NF2S-18.5 Gallon Fuel Tank QA2S-DESCRIPTION NOT AVAILABLE SBAS-Power Steering SCES- Wrapped Steering Wheel SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TBCS-Compact Spare Tire TBMS-Tire Carrier Winch WJDS-15X7.0 Styled Steel Wheels XBSS-Pickup Box XFAS--35F Protection Anti-Freeze YAAS-Build To U.S. Mkt. Specifications Z1AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail 161S-Zone 61-Atlanta *X8-Cloth Low-Back Bucket Seats -Q8-DESCRIPTION NOT AVAILABLE ADA-Light Group ALN-Body Color Bumper Group BAYP-105 Amp Alternator BCYP-95 Amp Battery CACP-Low Back Bucket Seats CDBP-Reclining Front Seats CUF-Full Length Floor Console DGB-All 4-Speed Automatic Transmissions DHSP-Floor Mount Automatic Shift Lever EAAC-All Engines ERB-4.0L I6 Engine GEC-Front Left Side Sliding Window GFDA-Rear Sliding Window GNBP-Driver Side Illuminated Sun Visor GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZA-Manual Remote Mirrors HAA-Air Conditioning JAYA-DO NOT USE - See JP, KA classes JGBP-Digital Clock JHAA-Var Intermittent Windshield Wipers LAJP-Headlamps On Warning Chimes LBBP-Courtesy Lamps LBDP-Ash Tray Lamp LBEP-IP LED Ambient Light Pipe LDHP-U/Hood, Removable/Rechargeable Lamp LHDP-Headlamp Off Time Delay LPEP-Cargo Lamp MDA-Front License Plate Bracket PA2-DESCRIPTION NOT AVAILABLE RAAC-All Radio Equipped Vehicles RABA-AM/FM Radio RCDP-4 Speakers SUA-Tilt Steering Column TAAC-All Tires TAEA- Tire Size:TBD TMWA- All Terrain Tires YEP-Manuf Statement of Origin YGBA-1 Additional Gallons of Gas YGGA-9 Additional Gallons of Gas Z01P-Rear Spring Group I Z59P-Left Front Spring Group Ix Z79P-Right Front Spring Group IX 5AMA-JF/3450 Vehicle Family 5KNA-Metro Cars of Detroit
