Does any one know what this is?
Sorry if its a horrible pic, its a hard angle to get to...I`m not sure what that white/yellow plastic piece is at the top of the brake pedal above the brake switch.
Long story short, I pulled the MC and Booster from a 99 Grand cherokee to put into my 89 Comanche(automatic trans). But I`m pretty sure I took too much off when I was flattening the part of the rod the brake switch would sit on. It stays loose and this gives me no brake light.  I was thinking I could put a universal brake switch where this white plastic piece is but it is actually plugged up and I do not know what it is.  I couldn`t find it in the Haynes manual and I didn`t know what to call it to search for it in google. Any insight is greatly appreciated.
Reminds me of a clutch switch for disabling the starter or disengaging cruise control. Maybe it part of the cruise control? Just a early version with a separate switch for the brake light and another for cruise control?
Sent from my iPhone using Tapatalk Pro
I dunno. On the 91 up XJ the brake switch has a bigger plug and does 3 functions, brake lights, cruise control, siginsl to lock and unlock torque converter.
Not sure about Renix era jeeps. Some google pics look like your switch
4 minutes ago, Ωhm said:
Its the Cruise/Trans Switch. Serves two purposes:
  1. Vacuum dump for cruise when brake lights are ON.
  2. Disengage Torque Converter when brake lights are ON.
Thanks, that is good to know. I don`t know that I`d have figured that out by myself
Out of the box and on the bench, doesn't that switch (SL186) have one set of contacts NC and one set of contacts NO? I would think you need both contacts to be NC.
You could use one switch, NC, and wire the TC side through a relay, TC side could be NC or NO, wouldn't matter other than how you wire the relay.
Brilliantly simple to do. Explaining so gets one mired in the mud.
Or one could mod the bracket for two switches.
Either way, I don't bother as one of the jesters will dismiss me as usual. :smile:
Yes you could use relay logic here or could one just take the output of the correct contacts (connector connected) and feed the output wire (connector not connected) of the other set of contacts. This would a$$ume that all current requirements are meant and that the switch is as I claim.
Brake switch is NO until brake switch is actuated.
TCU is NC and goes open when brakes applied interrupting power to the torque converter lockup solenoid.
Looking at the wiring diagrams (88ELECT, pg20,pg71) both switches close when brake pedal is depressed. How should we address the NC & NO verbiage, when installed on the vehicle or out of the box and on the bench?
On 8/24/2018 at 9:02 AM, cruiser54 said:
Yup, it is.
I converted one of my Jeeps to the single switch from a GM car. bit of a pain.
this looks like the most viable option for me.... what did you have to do?
I`m not that bright... especially when it comes to electrical.... was it plug play? or did you have to do some more work?
Use an HO 91 or above brake pedal switch and re-purpose it. Each switch has three sets of contacts; two NC (normally closed) and one NO (normally open) set of contacts for brake lights, cruise, and torque converter lock. It mounts the same way as the switch pictured above. It will have to be hardwired in or use an HO brake pedal switch connector w. a pigtail.
By the way, your TCC switch is not adjusted properly. Give it a shove till it hits the pedal.
