a bum with money Posted July 19, 2018 Posted July 19, 2018 I was just curious if there was a better way to use the search function of forums. right now it seems that you can only search just 1 word, for example "keyless" but "keyless entry" and get more specific results. am I just not using it right or...……?
kryptronic Posted July 19, 2018 Posted July 19, 2018 The search is weak. Maybe we need to update it or get a plugin. There are no real controls like you would expect (AND, OR, NOT, params, etc). "keyless entry" will hit on anything with "keyless" or "entry" in it.
HOrnbrod Posted July 19, 2018 Posted July 19, 2018 7 minutes ago, kryptronic said: The search is weak. Maybe we need to update it or get a plugin. There are no real controls like you would expect (AND, OR, NOT, params, etc). "keyless entry" will hit on anything with "keyless" or "entry" in it. There's an option to select the phrase "keyless entry" (or any other phrase) after the first search.
Ωhm Posted July 19, 2018 Posted July 19, 2018 My "keyless entry" search only finds keyless entry. Seems to be working fine for me. Tried searching both 'signed in' and 'signed out', same results.
a bum with money Posted July 19, 2018 Author Posted July 19, 2018 17 minutes ago, Ωhm said: My "keyless entry" search only finds keyless entry. Seems to be working fine for me. Tried searching both 'signed in' and 'signed out', same results. strange, couple days ago I had sifted through pages of posts trying to find any reference to keyless entry. just tried it now and low and behold all the results that were scattered through several pages, are now on the first page! I like it. maybe someone read my post and pulled some strings or something. but I'm still not impressed. BTW...….out of the blue about a month ago I started getting email notification emails again...………..sha na na na na na na na na na na na na naaa
kryptronic Posted July 19, 2018 Posted July 19, 2018 Maybe I'm doing it wrong. I'll dig into it. Thanks for the tip, Don.
HOrnbrod Posted July 20, 2018 Posted July 20, 2018 15 hours ago, kryptronic said: Maybe I'm doing it wrong. I'll dig into it. Thanks for the tip, Don.
Jeep Driver Posted July 20, 2018 Posted July 20, 2018 I have found that most forum search engines are rather clunky, not all, most. I have had better results searching outside the forum, google- 'keyless entry comanche club'. You may also find more information that way. Also, depends on spelling, is it keyless or key-less or key less? Most weak search engines are spelling dependent.
kryptronic Posted July 20, 2018 Posted July 20, 2018 1 hour ago, Jeep Driver said: I have had better results searching outside the forum, google- 'keyless entry comanche club'. Right on. Even better is a direct site query at Google, with quotes to match exact phrase: site:comancheclub.com "keyless entry" 20 hours ago, HOrnbrod said: There's an option to select the phrase "keyless entry" (or any other phrase) after the first search. I played around a bit, there is an option there that I read past every time I did a search (and I bet others did too). Thanks for pointing it out. It's still not the best search engine, but that definitely makes it usable. I've opened a tech job on this to look into further. There has to be a way to get defaults set and get the engine itself running better.
Pete M Posted July 20, 2018 Posted July 20, 2018 the hardest issue to overcome will always be that there are a plethora of ways to refer to the hunk of metal behind the engine that shifts gears around. even google doesn't know that Peugeot, ba-10, ba-10/5 puke-goat, transmission, tranny, giantpileofcrap, boat anchor, etc are all needed in the search.
