GreasemonkeySC Posted July 18, 2018 Share Posted July 18, 2018 My MJ is stuck on the defrost vents. The useless manual I have had nothing with actual locations of vacuum actuators. I need to test it, and try to find a replacement if it's faulty. I'm about to do a compressor, accumulator, expansion block, flush, 134a conversion, blower resistor, and duct cleaning. Can someone please give me the exact location of the mode for actuator? Quote Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 18, 2018 Share Posted July 18, 2018 Defrost is the HVAC default when you have a vacuum leak. Normally this happens where the plastic vacuum line passes through the front bulkhead to the vacuum canister behind the bumper. Check this plastic line from the firewall all the way out for leaks. Quote Link to comment Share on other sites More sharing options...
Minuit Posted July 18, 2018 Share Posted July 18, 2018 There are several actuators, one for each "mode door". They're all mounted on the left side of the HVAC box, except for the recirculation door. As Don said it's more likely you have a vacuum issue, as the air will blow out of the upper defrost vent if no vacuum is available. Quote Link to comment Share on other sites More sharing options...
dvitha Posted July 18, 2018 Share Posted July 18, 2018 stuck in defrost is normally a vacuum leak. default no vacuum is defrost. I would check your vacuum lines running out of cab to the ball. Quote Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 19, 2018 Share Posted July 19, 2018 2 hours ago, dvitha said: stuck in defrost is normally a vacuum leak. default no vacuum is defrost. I would check your vacuum lines running out of cab to the ball. Are you a parrot? Quote Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted July 19, 2018 Author Share Posted July 19, 2018 Not a vacuum leak between the controls and the motor. I've checked that already. Justin need to figure out where the problem lies.Thanks for the illustration. I'll check them tomorrow. Quote Link to comment Share on other sites More sharing options...
Eagle Posted July 19, 2018 Share Posted July 19, 2018 The problem is almost certainly where the vacuum line runs from the vacuum reservoir behind the front bumper under the battery tray. The hose deteriorates, a vacuum leak developes, and with no (or low) vacuum the vents default to the defrost position. It could also be a leak in the reservoir canister itself. Quote Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted July 19, 2018 Author Share Posted July 19, 2018 The problem is almost certainly where the vacuum line runs from the vacuum reservoir behind the front bumper under the battery tray. The hose deteriorates, a vacuum leak developes, and with no (or low) vacuum the vents default to the defrost position. It could also be a leak in the reservoir canister itself. So I tested that section with my vacuume pump & gauge. Pump down a vacuum, and check the gauge for loss. I tested it at the T up by the firewall. No vacuume loss. I decided to check it again and found that the previous owner had removed the canister, and capped off the line just forward of the battery. This guy cut more corners, and did more shady work than I've ever seen before. Quote Link to comment Share on other sites More sharing options...
Eagle Posted July 19, 2018 Share Posted July 19, 2018 That's the problem, then. Under light throttkle the engine has enough vacuum to hold the actuator doors where you set them but when you accelerate or go up an incline, as you know the throttle opens and the engine vacuum drops. The canister is a vacuum reservoir to maintain vacuum under those conditions. You can get a canister from any wrecked XJ. There are two types -- the ones with cruise control have two chambers, one for the HVAC and the other for the cruise control. If your truck doesn't have cruise, you can use either type. Quote Link to comment Share on other sites More sharing options...
schardein Posted July 19, 2018 Share Posted July 19, 2018 26 minutes ago, GreasemonkeySC said: So I tested that section with my vacuume pump & gauge. Pump down a vacuum, and check the gauge for loss. I tested it at the T up by the firewall. No vacuume loss. I decided to check it again and found that the previous owner had removed the canister, and capped off the line just forward of the battery. This guy cut more corners, and did more shady work than I've ever seen before. HAHAHA I had the same issue with my $400 XJ. It seemed he went out of his way to do poor repairs. Just one example, he cut one of the support rods for the wiper transmission assembly, I suspect because he couldn't figure out how to get it out. Then he taped it back together with electrical tape (yes, yes he did). Me, wondering why the wipers are out of sync....hmm, never seen this before. And I had a leak at the vacuum ball... defrost only. Quote Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted July 20, 2018 Author Share Posted July 20, 2018 🤣🤣🤣🤣🤣🤣🤣🤣🤣 Quote Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted July 27, 2018 Author Share Posted July 27, 2018 Gonna make a new vacuume reservoir tomorrow. I've got an old stainless water bottle that's not the insulated kind. The lid has a very good thick seal on it, so I'll put an 1\8" barb through the cap, hose clamp it somewhere, and connect to the existing vacuume line. Redneck, I know, I know...... But the one I made from an empty R134a can has been in my Rubicon for about 8yrs without fail! Quote Link to comment Share on other sites More sharing options...
AZJeff Posted July 27, 2018 Share Posted July 27, 2018 On 7/19/2018 at 3:28 PM, schardein said: Just one example, he cut one of the support rods for the wiper transmission assembly, I suspect because he couldn't figure out how to get it out. Then he taped it back together with electrical tape (yes, yes he did). And I had a leak at the vacuum ball... defrost only. You wind the award for this year for finding the most hillbilly auto repair done by a previous owner!! Quote Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted July 27, 2018 Author Share Posted July 27, 2018 You wind the award for this year for finding the most hillbilly auto repair done by a previous owner!! Yer a-ward is a dollar store Christmas tree, decorated with beer can lights, and most of the bulbs is still working. Quote Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted August 12, 2018 Author Share Posted August 12, 2018 You can get a canister from any wrecked XJ. There are two types -- the ones with cruise control have two chambers, one for the HVAC and the other for the cruise control. If your truck doesn't have cruise, you can use either type. Finally got time to install a temporary vacuume canister while I sort out the problems. BTW: still no vacuume leak, and mode stuck on defrost. Quote Link to comment Share on other sites More sharing options...
AZJeff Posted August 14, 2018 Share Posted August 14, 2018 Dumb question: If you apply vaccum to the system where it enters the passenger compartment, does it HOLD vacuum, or drop instantly? Quote Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted August 14, 2018 Author Share Posted August 14, 2018 It's holding, so I have a bad control panel.Just have to verify with the gauge. Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
