  • Replies 96
13 hours ago, 89 MJ said:
As a whole, it looks pretty darn solid though. The soft spots in the frame are unfortunate, but don’t look too bad.
You are correct. It is still quite solid. Nothing that would question viability of this project at least. It's rough where the rear bumper brackets would bolt too. Oh well, rust belt woes haha
Last night I made more teardown progress!
Arguably got the hardest part out of the way. Front and rear glass removed.
I was able to save the rear window gasket too!20240415_182028.jpg.d678a4921baf0aaa679ce5f2fd4d1bcb.jpg
The windshield though.. did not save.
20240415_182034.jpg.e220ffbb16a6d62aaa7e971cef63a997.jpg20240415_182037.jpg.7f5dee13f7343d5e96b29a4c594feee6.jpg
The slider I probably won't use again. The seals are failing and ir was leaking into the cab from the bottom corners. I have a cl lawerence 3 pane slider I'm thinking about using instead
Just chugging right along here!
Front and rear shocks are out, fenders off, heater core out, pulled the firewall insulation, wiper motor is almost out, all the wiring is removed.
I picked away at the rust and scale to assess rust damage. Cab corners are gone. Both rockers are paper thin, driver floor is gone, passenger floor is decent. I've got two patches to do at the back of the cab where two drain plugs go. Driver fender is rotted at the bottom. Passenger fender was replaced at some point and has a date stamp of '92 on the back but it's good.
Big strides! Major progress! Even with the rust.. I'm still happy with the progress.20240416_191207.jpg.ac0b37e8ecb169c4fa4a142147b1d57e.jpg20240416_191210.jpg.529732b9d835e0faaaafb1aceba353cf.jpg20240416_191217.jpg.28f18f0a550b480e50b79af30acb4a96.jpg20240416_191229.jpg.0019e92ce83e0f04f1456e6611958cb0.jpg
  • 4 weeks later...
Alright, the clock is a ticking now! June 3rd Candace has a date with the sandblasters so I've got to put the hammer down own getting her as naked as possible.
The interior is basically just a steering column now.
Door panels have been removed and the doors are about ready to be gutted.
I've got sway bar, motor/ trans and brake and fuel lines left.
Doors and hood are the only bolt on panels left on the trick.
If I have time I'm going to get as much seam sealer as I can out of the cab, maybe remove the floor braces and cut out the rockers and cab corners so it can be blasted behind there.
And right after that my work will be epoxying the chasis.20240513_181738.jpg.d27b828d253521b77146b49f16389a7b.jpg
Both doors. Never been opened since sealed in 86!
A little more progress!
Doors and steering column are the only thing left to address with the interior.
After I took the photo I decided to pull the 4x4 shifter.
Sway bar, track bar, steering box, all unbolted.
and removing the sway bar links i discovered that the torx bolt for the axle side of the link wasnt knurled. It was smooth. Was that like that in 86?20240514_184826.jpg.836da4afe5ba87a93a30b9dcfd69d848.jpg
Updates!
2 weeks ago I yanked out the engine, trans and transfercase from the jeep and put it away for storage.
Trans and transfercase I won't likely use so at some point they will be up for grabs. The engine I'm not sure about yet.
I also got the bed loaded up with parts and put away for storage for now.
After all that was taken care of I went on a trip to vegas for a week for some long overdue r&r.
After getting back from vegas I had the weekend get a lot of stuff done before work. Yard work and the like. I also had the weekend to get the truck ready for sandblasting too. I wish I could have removed the seam sealer myself to save the blaster some time but oh well.
I got her all the way down to a bare shell and loaded up on the trailer to be dropped off today 6/3/24.20240602_195729.jpg.c02437714d8fec56c1f1bdec36fbcb9e.jpg20240602_195746.jpg.183d9ec41e4f9af76571d96b8d8b61ec.jpg20240602_195753.jpg.891a07c30095e2801cffd4f0bf4c4121.jpg20240602_195800.jpg.f9e3a299808dfefbf21ce6a0e0fc2783.jpg
In the mean time I've been tinkering with the dana 44 axle that will be going into the truck. The bolt that holds the brake hose to the axle had broke off so I tried extracting it. Turns out it refuses to leave. I had quite the fight with it.
Tried welding nuts to it and the stud would only break shorter until it was flush. Then I tried an easy out and it snapped in the bolt. Somehow got lucky and managed to weld to it and extract it. Thinking about just drilling it all the way out and retapping it at this point.20240605_201042.jpg.262fd3eb63aa775cb4dfb23ae8298365.jpg
Got the hole drilled and taped for the axle. Got it stripped apart a little more. A happy surprise inside and a not so happy surprise inside.
The happy surprise!
Clutch packs!
And a 3.54 gear ratio. Which would in theory make it bolt in ready for my truck but..
20240616_182259.jpg.43b143ce4a4ae1f1df41c98f047377e3.jpg20240616_182237.jpg.92e3656e757518a032aec2215e9a28e9.jpg
Spider gears got a little chewed up in its years of use. And it looks like there was a roll pin holding the spider gear dowel in place and the rollpin sheered.
And God only knows the condition of those clutch packs.
So not actually bolt in ready.
Got Candace back from the sandblasters mid week! She's better in some spots and worse in others than I thought. But still very fixable. And they did a pretty good job for $700!
20240703_130331.jpg.fac28af7bdd7cdd0dd0989e15876cb90.jpg20240703_130339.jpg.8fc2310e7eac74a7d2a50c37d0d7aa03.jpg20240703_130344.jpg.776eeadf2628c8c6838f82548ddbaf56.jpg20240703_130352.jpg.fa72a21ffc37ec94b7766d87dfc986a5.jpg20240703_130403.jpg.5eaadf7f3ced21243390c072721fd256.jpg
they didnt clean her out though so i had to make sure i didn't have anyone behind me...:sad2:
Project Candace is underway again!
Made some progress tonight!
Passenger side floor braces were removed for floor patch. For an 86 the passenger floor is considerably clean! The braces are even reusable. The main brace does have pitting but it's not compromised. 20240811_164647.jpg.44d1027856fbe7c20b2d7bd1634d6ade.jpg
drilling out the spot welds sure took some time though and my back doesn't thank me for it. Haha
20240811_184809.jpg.680af15c6470a8fd8c85f4dca4fc06ac.jpg20240811_200235.jpg.b20f176c61d10421a58408757091dce2.jpg
Progress progress progress!
Tackled the drivers floor braces. Not nearly as fun because I couldn't tell where some of the spot welds were and the brace turned out to be too thin and folded on me.20240812_204442.jpg.b265cbd78c7688bcf7a4ca5136b9a769.jpg20240813_204742.jpg.50b62ab8e03b41584637ed01b45fbc1d.jpg20240813_210033.jpg.d240c6597b16c73e5af3e33b538bcc55.jpg
Getting the brace off revealed some.. less than desirable results. I wish the driver side was as nice as the passenger side. The floor is toast a ways up.20240813_210043.jpg.14c0f5d33e43078f0d80fcf27046ee76.jpg
cleaning out the rail was fun too. Full of black beauty and rust flakes.
And although not terrible, still not great to find a small portion of the unibody slightly compromised. Easy fix and small spot but not one I wanted to do.20240813_211024.jpg.217066c4586ce7e8acabe41daa64c746.jpg
  • 5 weeks later...
As I pinch pennies for some more sheet metal I figured I'd do some more work elsewhere. I went back to the d44 to do more work!
20240909_175048.jpg.41daef2d6bedc7d8e8d4c6ec37106d6a.jpg20240909_175055.jpg.0bb33de1dd554cbcf6fc8fcbf54d5e68.jpg
Center chunk removed! It's an absolute mess! Spider gears are chewed, the pin is held in by hopes and dreams, the amount of glitter and chunks is astounding. Seals are shot too. It was just a list of discoveries that I didn't love.
I also found out one side of the axle had new bearings installed.. and I could pull the race out by hand.. so someone may have spun a bearing? And I have to deal with that. But I'm going to make it work!
In the meantime I scuffed and coated the whole axle in flat black rustoleum. That turned out nice at least!
Next step is to take the pinion gear out, remove the rest of the races and pressure wash the chunks and glitter out of it so I can put it back together and put it under the truck.
  • 7 months later...
Back on Candace again. With the nice weather hitting it's making me feel motivated.
Ordered key parts inner rocker and full floor for the left side as it's all rough. And started cutting away.20250414_180008.jpg.803a49395abf096cb55d4cc5dcf932ae.jpg
So regarding key parts rockers. They are good. But a little short here and there.
one end doesn't really go behind the cab corners like it's supposed to.20250414_184123.jpg.84c1261de950513f78b0773ab85d10fe.jpg
And where the sill plate goes it's just flush to the welded metal.
I'm not sure if i got bad rockers or if I'm going to have to get crafty to finish them up..
More progress stripping Candace down.
Tackled the inner rocker last night. The amount of seam Sealer you have to fight is absurd.
Outer rocker cap. Half the welds did not hold from the factory.
What's left of the outer rocker behind the cab corner. Will have to figure out repairing and stitching to the new rocker.
And a clean looking at the inner!
The welds that hold the inner rocker to the cab i found were.. crude. Or just not there. There were several spots that should have had spot welds and didn't.
Beads of welds in the cab holding the inner to the B pillar. One hidden behind lots of seam seaSealer.
After cutting and grinding random degrees of welds it came out.
Key parts comparison. The seat belt nut is spot on.
Epoxy primed at work.
20250418_093518.jpg.587bba0a80b25396287756edbb8ac578.jpg20250418_093523.jpg.d18e5740fe36fe629935846cc28d65e7.jpg
now i need to fix the kick panel extension that meets the inner rocker and it can go on!
