KANTANKRUS Posted May 19, 2018 Share Posted May 19, 2018 Between a D35 and a Ford Explorer 8.8? Link to comment Share on other sites More sharing options...
Egm89 Posted May 19, 2018 Share Posted May 19, 2018 Ifrc an 1 inch or 2 Link to comment Share on other sites More sharing options...
Pete M Posted May 19, 2018 Share Posted May 19, 2018 little under an inch per side. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 20, 2018 Author Share Posted May 20, 2018 I am just trying to figure out, what I need to do, to get it to track right. Here in the Nazi state of PA, wheel spacers are a big no-no! Link to comment Share on other sites More sharing options...
Pete M Posted May 20, 2018 Share Posted May 20, 2018 do you already have the 8.8 installed or is this hypothetical? Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 20, 2018 Share Posted May 20, 2018 Get a Super 88 kit. It widens the axle without spacers, and eliminates the C-clips. If I was to run an 8.8 I'd get it. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 22, 2018 Author Share Posted May 22, 2018 On 5/20/2018 at 1:27 AM, DirtyComanche said: Get a Super 88 kit. It widens the axle without spacers, and eliminates the C-clips. If I was to run an 8.8 I'd get it. Sounds like a plan! Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 22, 2018 Author Share Posted May 22, 2018 On 5/19/2018 at 11:50 PM, Pete M said: do you already have the 8.8 installed or is this hypothetical? Yes, my rear axle is a Ford 8.8! Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 22, 2018 Author Share Posted May 22, 2018 Do ya got a link, for that Super 88 kit? Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 22, 2018 Share Posted May 22, 2018 2 hours ago, RestoringNV said: Do ya got a link, for that Super 88 kit? No, I hope they still make it. Superior Gear and Axle, IIRC. I can look when I get in from the shop tonight. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 22, 2018 Share Posted May 22, 2018 Here, not 4x but similar principle. If I were dead set on 8.8 for my truck, I'd find the housing and gears I want, then send off to a rear specialist and have it retubed with 9" ends, and have axles made. Set up for discs. Yeah, will cost about $800 or so, but once done, it's done. And you can correct that horrific off-set. Skip to about 5:00 Link to comment Share on other sites More sharing options...
kryptronic Posted May 22, 2018 Share Posted May 22, 2018 On 5/19/2018 at 10:32 PM, RestoringNV said: I am just trying to figure out, what I need to do, to get it to track right. Here in the Nazi state of PA, wheel spacers are a big no-no! Spacers are a no-go in PA, but adapters are OK. So if you use a spacer that bolts to the axel, and your wheel bolts to the spacer, your inspection guy shouldn't have an issue. With that said, in PA it is best to use wheels with the proper offset, but make sure your tread is nearly 100% covered by your flares. Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 22, 2018 Share Posted May 22, 2018 Apparently Superior went out of business, guess I missed that, but Yukon makes the same kit. https://www.yukongear.com/productdetails.aspx?ProdID=10255 East Coat Gear Supply has it listed at $588. I'd talk to WayneHartwig on Pirate (DiffsOnly) and see what he can do, I'd guess probably right around the $500 mark. Link to comment Share on other sites More sharing options...
