when anyone gets a chance, can we confirm that these measurements are center of ujoint cap to center of ujoint cap?
Quote
lwb,_2.8,____tf 3speed,____np207,_amc20= 53"_____d35= 54"
lwb,_2.8,____ax5-ax4,______np207,_amc20= 53.75"__d35= 54.75"
lwb,_2.8,____ax5-ax4,______2wd,___amc20= 63.75"__d35= 64.75"
lwb,_4.0,____aw4,__________np231,___d44= 47.5"___d35= 48.25"
lwb,_4.0,____aw4,__________2wd,_____d44= _______  d35= 59.5"
lwb,_4.0,____ax15-ba10/5,__np231,___d44= 49"_____d35= 50"
lwb,_4.0,____ax15-ba10/5,__2wd,_____d44= ________d35= #
swb,_4.0,____aw4,__________np231,___d44= 41.25"__d35= 42.35"
swb,_4.0,____aw4,__________2wd,_____d44= 52.125"_d35= 53.125" *
swb,_4.o,____ax15-ba10/5,__np231,___d44= 42.25"__d35= 43.25"
swb,_4.0,____ax15-ba10/5,__2wd,_____d44= 52.125"_d35= 53.125" *
lwb,_2.5,____ax5-ax4,______2wd,_____d44= 63.75"__d35= 64.75"
swb,_2.5,____ax5-ax4,______2wd,_____d44= 57.5"___d35= 58.5"
lwb,_2.5,____ax5-ax4,______np231,___d44= ________d35= 53.25"
swb,_2.5,____ax5-ax4,______np231,___d44= ________d35= #
lwb,_2.5,____tf 3speed,____np207,_amc20= 53"_____d35= 54"
My 88 SWB 4.0 ba10 might be 1/8 inch longer.  Upgraded to AX15 years ago but same shaft.  Bought truck new so no changes.
swb,_4.o,____ax15-ba10/5,__np231,___d44= 42.25"        I've got 42 3/8".
23 hours ago, MeanLemons said:
It’s currently raining outside.  I will measure my 88 MJ with 4.0L and 2wd AW4 & D35.
It’s 59.5” long
wait, that's the same as Don's and he has the d44.  :confused:   every one is measuring center to center, yes?
Si. My driveshaft, slip yoke, and pinion yoke are not stock, so if Mean Lemon is stock, he's probably correct for his configuration.
Yes. Center of u joint on the slip yoke to the center of u joint on the axle.
Although I currently have a 8.25 on it, I still used the same driveshaft from when it had the d35 on it.
The driveline shop in town must have had this, because when I swapped the AW4 into my
SWB - 4.0 - BA-10 - NP 231 - D44 he shortened the shaft 1" (and painted it too :beerbang:).
2 hours ago, Pete M said:
no one else can be bothered to crawl under their truck to verify a measurement?  :(
Mine isn't useful info, I don't think?  I have a SYE.
Il try to verify the 86 2.8 ax5 np207 d35 this weekend. The drive shaft has to be in that damn shed somewhere.
