New brake booster without new MC
Basic question. Do I need to replace MC when replacing booster?
I know my booster is crapping out. I have the in-cabin vacuum hisses going on. I see them sold as a unit and individual. And, see folks online usually replace both. Just wondering why.
If you installed a new M/C, and the next day your booster went bad and required replacement, would you replace your one day old M/C?  NO.  What about a month old?  No.  A year? probably not.  If the M/C is original to your 30 year old truck, it might be a good idea to go ahead and replace it.  I consider this a common sense approach.
On 4/18/2018 at 10:28 AM, HOrnbrod said:
Run through the below tests. It may be all you need is a new booster check valve.
http://www.classicperform.com/TechBook/BrakeTroubleshoot.htm#testbooster
While replacing both is likely the way I'll go, I did some of the testing with these results.
Test 1: I think the pedal dropped more than 1/4"
Test 2: I couldn't tell much of a difference.
Test 3: Pedal did not drop after 30 sec. But, did slowly drop with continued pressure beyond 30 sec.
Power check valve was bad, replaced it BEFORE running the tests.
That's as far as I have gone as I don't know what "18 in. of vacuum" means.
9 hours ago, HOrnbrod said:
Low vacuum is probably not your problem with the brakes.
Does that rule out the vacuum booster? It's a loud hiss in the cabin, reduces/stops when brakes depressed.
On 5/3/2018 at 10:16 AM, HOrnbrod said:
I'd rent a gauge at Autozone or somewhere and check engine vacuum. If okay, then replace booster, booster/master, or upgrade to double diaphragm booster brakes. Your choice.
:thumbsup:
