Thats what I thought =p
I had a local upholstery guy fix a few little tears and vinyl panels.. that's why there is an extra seam across the seat
Sent from my Pixel 3a using Tapatalk
On 10/31/2020 at 10:56 AM, rosco11 said:
It's a mystery from the previous owner, I'm thinking cb antennas..maybe?
look like a great place to mount some backup lights. :L:
  • 1 year later...
How about a project update after a solid year and a half of no new news?!?  Here we go! We can start with about 4 years ago I met this amazing girl while on a work trip in Washington. We traveled together and made a long distance relationship work for over 3 years. A short time after Covid19 spread across the country, I lost my job in a company restructure. Carly and I took advantage of that crap situation and we decided to get together and I made the move from Houston to Washington. The MJ was not running at the time with a suspected fuel pump problem. I decided to go ahead and coordinate shipping the truck up once I had made the move. Major props and thanks to my dad for having a mechanic friend of his stop by and swap in a new fuel pump I had ordered. Started right up!
I immediately started getting truck transport bids and got one set up to deliver. Carly and I were living in her apartment at the time but it had a nice parking garage. My dad coordinated the load up of the Jeep and the driver made his way across country. A few days later he showed up right outside the apartment building and had it unloaded. I drove it to it's new designated spot in garage. Fun driving with no shocks yet..haha!
Since then, we have bought a home, got engaged and now the Comanche has a nice garage to call it's own! I'm looking forward to the next couple of projects. I'd say we are about 80-85% done with the full build plan!  More to come..stay tuned!  Thanks for following along!
Finally got to cross a project off the list on the Jeep Comanche. Got a new serpentine belt and a brand new harmonic balancer installed. Pumped to get the tools out again!
DAYCO 5060975 belt
DAYCO Powerbond Harmonic Balancer PB1439N
  • 10 months later...
This accessory project for the Jeep Comanche has been a long time coming. I've wanted to add auxiliary power and streamline easy connections. As the MJ project continues I'll be adding several electric accessories, switches and relays. I added 2 six slot fuse blocks. The right side is hooked up as Always On power. The left is Key On power. I added a big relay to control the key on power. There is an 80Amp inline fuse mounted near the battery. The cables are 6 AWG and let me tell you, I got them from Battery Cables USA, Great pricing and super easy to order lengths and terminal sizes. Plus, they even custom turned the terminals for the shorter cables to make the connections route as easy as possible. I mounted the fuse blocks with stainless sheet metal screws. I mounted the relay and the main ground by inserting rivet nuts, allowing bolt in vs self tapping screws. I've been super intimidated by wiring projects and did as much research as I could before putting this together. Once I got the diagram planned & laid out and all the components in hand, it wasn't too bad to install. More projects coming soon! I'm pumped to be back at it!
  • 3 years later...
Had a chance to work on the Comanche over the last few weeks. I had previously cut out the decayed heat barrier from the floor pans and firewall. Here, I custom cut and fit sound deadening butyl and closed cell foam heat barrier. The passenger side and transmission tunnel took me about 2 hours, the driver's side took about 3 years since my last post! Haha
I used Silass for the sound deadening and heat reduction and aluminum tape for all the seams except the cover on the trans tunnel
A maintenance item that had never been addressed was cleaning and lubricating the door latches. They were gunked with mega hardened 35+ year old grease and grime and whatever else the previous owner sprayed in there. I disassembled the door, removed the latches and soaked in mineral spirits for about an hour. Most of the junk softened and I could brush out with a toothbrush and the hard stuff with a pick. Got it lubed up with some lithium grease and it's working supa smooth!
IMG_20260904_125702_572.jpg.196cb8448514e93c09a294005f900c75.jpgIMG_20260904_125702_616.jpg.8530782a906a8772bec7c9197b94ae7a.jpgIMG_20260904_125702_633.jpg.41602ea24f28dc3054bfc4bad45c52dd.jpgIMG_20260904_125702_668.jpg.7383e09740c2ffbd5e15647e112b1421.jpgIMG_20260904_125702_464.jpg.fd60adf79df08e7b8ddac2458cd578e8.jpg
The Comanche is getting an upgrade! I'm not an audio expert at all, but the original truck only came with two tweeters under the dash. It's going to take some work to get all the brand new wiring mapped out and ran through the doors and to the rear pillars. Digging into it!
I have a lot going on with the Jeep truck, several open projects are getting worked on at the same time. I have the lower dash, instrument panel and doors all opened up right now. This is a cool part here, I'm installing door speakers. The truck did not come with speakers or wiring for the doors. The speaker bracket is already built into the door. I needed to cut through the door panels.
Many folks have done this before on Jeep XJs and Comanches. One thing I noticed was that the padded door panels get compressed and almost wrinkled because the door speaker bracket is inset and the speaker has to mount from the outside of the panel. As you tighten the mounting screws it drags and compresses the vinyl and padding into the inset. To prevent this small detail I wanted to create a spacer of sort. The inset is about 5-6mm deep. I was looking for all kinds of options, dense rubber sheet, wood and other options. I found a sheet of hardboard I had in the garage. It was 2.5mm thick. I made a template and cut out two pieces and glued them together making a perfect 5mm spacer. I spent way too much time in this little project but it ended up working out just right. I then cut out the speaker hole in the door panel, carefully, layer by layer. I glued the new spacer in place and set some sand bags on it overnight to dry and stay tight. More details to come as I keep making progress on these interior projects!
With the doors on the Comanche disassembled, I've finished installing the speakers and routed wiring. Created brand new vapor barriers by tracing the originals onto simple 3mil plastic sheeting. Used 3M Super 77 spray adhesive to lightly attach. Then I used my cheapo soldering iron to melt the fastener holes. It worked perfect!
Screenshot2026-09-173_15_50PM.png.82f8cd3f766514001dd17dd46dddc6eb.pngScreenshot2026-09-173_16_48PM.png.84d8cfe93d0eb53261998f3552735e8e.png
Made in Japan! With the Comanche lower dash and bezel removed I investigated why, how, what tha heck is going wrong with my column shift indicator needle being broke for the past 7 yrs. Turns out it was there and hiding the whole time. It operates with a wire connected to the column shroud. The column shroud is broke and wouldn't turn when the shifter rotates to the different gears. Those details and my fix for that is coming soon. The instrument cluster is very cool! But, We have some issues with that too. Gas gauge shows empty, speedometer also doesn't work. I wanted to see if there was corrosion or something obvious on the rear circuit panel but it all looks really good. I might have to pick the brain of some of you Comanche and Cherokee experts!
On the Jeep Comanche steering column shroud, 2 of the 4 tabs that hold it in place while it rotates, was broken. They are inside the shroud and would be difficult to rebuild or fix. I came up with a semi permanent solution to fix. This will hold the shroud to the column shifter. I ordered a 2" x 12" rubber strip. Cut it down to about 1.5" and notched out for the shifter connection. I got 2 black oxide 4" clamps and tightened them up. It works perfect! IMG_20260930_104051_938.jpg.b51478b9bc246b4a367c7d08b7d62266.jpgIMG_20260930_104052_055.jpg.e3d3894080631e5ba9d9b73b2ba3a001.jpgIMG_20260930_104052_080.jpg.0ffb15d448d4cb2d06fca93835589e47.jpg
