rosco11 Posted February 13, 2018 Posted February 13, 2018 https://www.facebook.com/groups/365589063510564/permalink/1526929260709866/?sale_post_id=1526929260709866
Gatorgirl Posted February 14, 2018 Posted February 14, 2018 Hey Don, Look at this again it's not a 2.5.
HOrnbrod Posted February 14, 2018 Posted February 14, 2018 Right you are. The valve cover threw me off. Have never seen a 4.0 aluminum valve cover like that with the front side exit vent tube.
rokinn Posted February 14, 2018 Posted February 14, 2018 4 speed transmission?? Did the 91 HO come with a 4 speed or do you suppose this is replacement with an earlier year??
Minuit Posted February 15, 2018 Posted February 15, 2018 That's a 2.5. The fan shroud is centrally mounted and much deeper than it is on the 4.0. Also, look how short the engine is. The 4.0 is nearly the entire length of the engine bay.
HOrnbrod Posted February 15, 2018 Posted February 15, 2018 3 hours ago, HOrnbrod said: Right you are. The valve cover threw me off. Have never seen a 4.0 aluminum valve cover like that with the front side exit vent tube. Never mind.
Minuit Posted February 15, 2018 Posted February 15, 2018 Squiggly SporTrucks are the best SporTrucks.
schardein Posted February 16, 2018 Posted February 16, 2018 20 hours ago, Minuit said: Squiggly SporTrucks are the best SporTrucks.
