HunterK Posted January 20, 2018 Share Posted January 20, 2018 Hey guys I need some help. Was driving down the road came to a red light sitting in 1st gear with the clutch in, it wanted to stall, right when I took off it stalled and the pedal went limp/ had no pressure. Is that a slave cylinder issue? Or what could be wrong? Thanks. Link to comment Share on other sites More sharing options...
75sv1 Posted January 20, 2018 Share Posted January 20, 2018 Could be the salve or the master cylinder for the clutch. I remember my master went out, then two weeks or so later the slave went out. What year? Link to comment Share on other sites More sharing options...
Eagle Posted January 20, 2018 Share Posted January 20, 2018 It could be the slave cylinder, it could be the master cylinder, or it could be the line connecting the two. Link to comment Share on other sites More sharing options...
Big Dan Posted January 20, 2018 Share Posted January 20, 2018 Same thing happened to me a few months ago. It ended up being the slave. Link to comment Share on other sites More sharing options...
omega_rugal Posted January 20, 2018 Share Posted January 20, 2018 is there a visible leak? could be master/slave or the link between... but if it`s not leaking fluid then is the master cylinder Link to comment Share on other sites More sharing options...
Marine1Texas Posted January 21, 2018 Share Posted January 21, 2018 Best bet is when you replace the slave replace it all. I been thru the Replace master then the slave went out then the line burst. So when I replace one every 6 to 8 years I do it all. Link to comment Share on other sites More sharing options...
jpdriver1 Posted February 2, 2018 Share Posted February 2, 2018 just sourced this out for mine today --- rock auto has m/c, slave cyl & hose ---- used 1990 ax-15 as reference, since that is what is to go in. Link to comment Share on other sites More sharing options...
