Hey guys I need some help. Was driving down the road came to a red light sitting in 1st gear with the clutch in, it wanted to stall, right when I took off it stalled and the pedal went limp/ had no pressure. Is that a slave cylinder issue? Or what could be wrong? Thanks.
Could be the salve or the master cylinder for the clutch.  I remember my master went out, then two weeks or so later the slave went out. What year?
just sourced this out for mine today --- rock auto has m/c, slave cyl & hose ----
used 1990 ax-15 as reference, since that is what is to go in.
