creepinmanche Posted January 9, 2018 Share Posted January 9, 2018 I'm gathering the parts needed for a full 97+ conversion. are there any factory lights that will fit with little to no mods? I'm probably going to end up building steel housings but would like everything to look factory if possible. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted January 9, 2018 Share Posted January 9, 2018 There are a handful of options that LOOK close, but all require some fabrication to make them work. Rusty's Offroad makes a steel housing that isn't cheap: http://www.rustysoffroad.com/rustys-metal-tail-light-housings-pair-mj-commanche.html Link to comment Share on other sites More sharing options...
creepinmanche Posted January 9, 2018 Author Share Posted January 9, 2018 1 minute ago, DesertRat1991 said: There are a handful of options that LOOK close, but all require some fabrication to make them work. Rusty's Offroad makes a steel housing that isn't cheap: http://www.rustysoffroad.com/rustys-metal-tail-light-housings-pair-mj-commanche.html yeah I'm fine with building some but trying to keep the body side of things as "factory" as possible. I would love to put the 97+ taillights in but I think they are too rounded for the square body. do you know which ones look decent off hand? Link to comment Share on other sites More sharing options...
DesertRat1991 Posted January 9, 2018 Share Posted January 9, 2018 Early 90's Dodge Dakota lights look very similar to ours but don't quite fit. Apparently, you can also get Cherokee tails to fit with enough blood, sweat, and fiberglass work: Link to comment Share on other sites More sharing options...
sinkrun Posted January 9, 2018 Share Posted January 9, 2018 If wanting to keep it factory looking why not just keep the factory lights restore them if you want them to look new its not hard. Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 9, 2018 Share Posted January 9, 2018 Use your stock lights. All you have to do is rewire them. Link to comment Share on other sites More sharing options...
crumbscomanche Posted January 10, 2018 Share Posted January 10, 2018 3 hours ago, DesertRat1991 said: There are a handful of options that LOOK close, but all require some fabrication to make them work. Rusty's Offroad makes a steel housing that isn't cheap: http://www.rustysoffroad.com/rustys-metal-tail-light-housings-pair-mj-commanche.html These are sweet, I didn't know Rustys made them. Doesn't look like there's a reverse light though :/ Link to comment Share on other sites More sharing options...
Dzimm Posted January 10, 2018 Share Posted January 10, 2018 Agree with Shelbyluv. Keep your factory tails and either cut and solder the old plugs to the new wiring or do some dremel work on the 97+ XJ bulb plugs to fit the MJ housings. Not only is it waaayy cheaper, it looks much better on the truck IMO. On mine I just dremeled the newer XJ plugs and they fit great. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 10, 2018 Share Posted January 10, 2018 2 hours ago, crumbscomanche said: These are sweet, I didn't know Rustys made them. Doesn't look like there's a reverse light though :/ Rusty's overseas C.R.A.P. supplier made them. They look like what they are - a poorly designed housing encasing a universal light LED fixture that costs $200. Link to comment Share on other sites More sharing options...
creepinmanche Posted January 10, 2018 Author Share Posted January 10, 2018 15 hours ago, sinkrun said: If wanting to keep it factory looking why not just keep the factory lights restore them if you want them to look new its not hard. I like the look of the 97+ tails and I feel it would finish the 97+ conversion through the rear as well as most of the conversion is in the front\center. didn't know if you guys have figured anything out for this issue or not. Link to comment Share on other sites More sharing options...
creepinmanche Posted January 10, 2018 Author Share Posted January 10, 2018 15 hours ago, DesertRat1991 said: Early 90's Dodge Dakota lights look very similar to ours but don't quite fit. Apparently, you can also get Cherokee tails to fit with enough blood, sweat, and fiberglass work: nice manche by the way. I just picked up my first and its a 87 sportruck 2wd 4 cyl 4 speed as of right now Link to comment Share on other sites More sharing options...
sinkrun Posted January 10, 2018 Share Posted January 10, 2018 13 hours ago, HOrnbrod said: Rusty's overseas C.R.A.P. supplier made them. They look like what they are - a poorly designed housing encasing a universal light LED fixture that costs $200. $200.00 each if I read it correctly. Link to comment Share on other sites More sharing options...
krustyballer16 Posted January 10, 2018 Share Posted January 10, 2018 $200.00 each if I read it correctly. Nah, for a pair. But for $200 they should fit better than they do. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
sinkrun Posted January 10, 2018 Share Posted January 10, 2018 My bad I miss understood I see it now. Link to comment Share on other sites More sharing options...
jpdriver1 Posted January 12, 2018 Share Posted January 12, 2018 saw a delivery truck this morning that had the oval led style lights, with back up lights in the middle Link to comment Share on other sites More sharing options...
