Waterpump?
A waterpump can/will weep before total failure.  It's actually a design 'feature' that it will leak before the bearing f's right off and leaves you stranded.  Brake clean the engine, observe for leaks after shutdown, as it easily it could be something else...  Change the part that leaks.
Ya ive done that, and its the water pump weeping
I don’t know if I would do it today, but back when I was a broke student/single dad going to/from school and my water pump on my old Rambler wagon started weeping (they didn’t warranty parts) I put a screw in the weep hole with black silicone and got by another two years with it. The bearing was fine (remanned pump and not Chicom bearings) so I took a chance.
