Rust Removal Above Inside Wheel Well
While under the MJ this week I noticed a fair amount of rust developing on both sides of the truck above the rear wheel wells (inside). I'm looking for a solution to remove the rust before it progresses and penetrates through the body. Is there a reliable chemical remover or am I stuck with mechanical removal? Aside from jamming a wire wheel up there, what options do I have (the area is tight).
Thanks.
what I would do is pull the bed off, mechanical as best I can, prep properly then coat with POR-15.  :thumbsup:
while you've got the bed off, you can attend to the rest of the nastiness that is undoubtedly on your frame or gas tank etc.
Sadly this nastyness is on the bed itself. Photo attached.
On 11/14/2017 at 9:47 PM, Jeep Driver said:
Ospho, soak, let set overnight, rinse, THEN...................choose your poison.
Ospho or similar will convert rust, not just choke it out.
On 11/14/2017 at 10:24 PM, Pete M said:
oh, I know.  :(   they all start up there.  it sucks big time.   the rest looks pretty good though :D
Thanks Fellas. I’ll give it a shot with a wire wheel and converter.
You could probably snake a hose up there and sand/media blast that area.
Oshpo is a muriatic acid converter.  It will work good too, but it has limitations if the rust is too flaky and blocks it.  You also want to get it rinsed out well.  If you wire wheel it first, it would probably work great.
Its just a tough spot to get to on that shelf (and hopefully not beyond...). Plan of attack for now will be to wire wheel everything I can, squirt a converter on it, and do my best with painting it (I guess ill give POR15 a shot). Just surprised on this issue as I had rinsed that area religiously after salt exposure the past few years. Oh well... I Guess.
With the bed on the frame, then yes  difficult to reach equipment to all the spots, and unable to address all clean up and coating. Bed would have to come off frame for this to be done thoroughly with blasting. I don't know what Hudy's plan is. Just offering my help. And letting all CC members that I have this available. Thank you!
This is probably a good idea... I’m interested. I have plans to pull the bed in the spring for paint and will take you up on this offer then. For now to minimize the rot progression ill hit it with a converter and hope for the best.
