Renegade Posted August 1, 2007 Posted August 1, 2007 I'll be running 32" tires. What gears will the old Renix 4.0/auto be comfortable with? I'd rather go a bit low in case I run 33's in the future. Will a D35 from a YJ bolt in to replace the 35 I have now? Might be able to find one already geared that has been yanked in favor of something stronger.
Drahcir495 Posted August 1, 2007 Posted August 1, 2007 Try this out http://www.4lo.com/calc/geartable.htm HTH Rich
Renegade Posted August 1, 2007 Author Posted August 1, 2007 Thanks! According to that, if I find a D35 from a 4-banger YJ with it's OEM 4.10's, it would work just fine(assuming it bolts in). I was leaning toward 4.56's, but that could wait.
offroader461 Posted August 2, 2007 Posted August 2, 2007 MY buddy runs 4.10 with 33's and he says they are fine...
oldjeep Posted August 2, 2007 Posted August 2, 2007 4.10's with 33's works just fine. For street use you could easily run 35's with 4.10's.
89eliminator Posted August 2, 2007 Posted August 2, 2007 i run 33x10.5s with 4.10s and it runs perfect. the engine isn't revving to high and the power is good.
JeepcoMJ Posted August 2, 2007 Posted August 2, 2007 so you're saying my 33's with 3.07's isn't a good thing? :P
89eliminator Posted August 2, 2007 Posted August 2, 2007 so you're saying my 33's with 3.07's isn't a good thing? :P not unless you want to get beat off of the line by a moped :D
JeepcoMJ Posted August 2, 2007 Posted August 2, 2007 uh...time to upgrade...in a few months...when I have money.
ORCA Posted August 2, 2007 Posted August 2, 2007 3.73 - 4.56 for 33's would be tits :cheers: I think anything above or below would be too much or too little. A buddy of mine has 3.73's and 33's, great for wheeling but not the best off the line ;) I've got 4.56's and 35's...it ain't that bad... :chillin:
Renegade Posted August 2, 2007 Author Posted August 2, 2007 I figured 4.10's would work, just don't want to be lugging the motor & heating up the trans. This truck will only see pavement.
JeepcoMJ Posted August 2, 2007 Posted August 2, 2007 I'm debating on 3.73 or 4.10 righ tnow as my 89 will be the commute truck from here to whitewater (45 min.) for school and will still regularly see highway travel. 3.73 sounds best to me...
87manche Posted August 3, 2007 Posted August 3, 2007 I'm debating on 3.73 or 4.10 righ tnow as my 89 will be the commute truck from here to whitewater (45 min.) for school and will still regularly see highway travel. 3.73 sounds best to me... what size tires? 3.73 has turned out to be a great highway gear comprimise. my junk get's 22 on the highway loaded for weekend wheeling with the street 31's on it. it's a bit lacking on the trail with 34's, I wish I had 4.56's then, but it's not terribly bad, I don't abuse the clutch that much.
pingpong Posted August 4, 2007 Posted August 4, 2007 To me gear selection is partly bassed on driving style, and needs for fuel economy. Also it helps to keep your motor in the peak power range for your tires. I always say go bigger/deeper. I say 4.56's or 4.88's that way when inchitis hits you wil be set for gears
Renegade Posted August 5, 2007 Author Posted August 5, 2007 I went for a cruise tonite & noticed it is pretty doggy taking off with the 3.55's & "215's". I'm leaning more toward 4.56's now since I will mostly drive short trips & would like the added acceleration. It's not going to be a daily driver. More like a "whenever I feel like it" driver, so I ain't TOO worried about mileage.
jared Posted August 5, 2007 Posted August 5, 2007 when i decide to upgrade i am going with 4.88's and 33's 8) but i have a stock 4 bangler tj with 4.10's already :D
Renegade Posted August 5, 2007 Author Posted August 5, 2007 I also have a 4 banger TJ. Running 4.88's with 36" Swamper SX's. Hasn't seen 5th gear in years :roll:
