87 jeep Comanche tranny
So I have a 87 jeep Comanche 2.5 longbed and the tranny has a tick in it. It tickets in all gears except 4th and its a 5speed and it ticks in neutral except for when the clutch is it. What do tall think the problem could be? Also I have a 4speed tranny in my 87 2.5 short wheel base and it's like an inch shorter. Would the transmission work if I swapped it to my longbed?
Sent from my SM-G900V using Tapatalk
Ax4 (4speed) & ax5 (5speed) are the same except for fifth gear, as long as both transmissions are the same, 4 wheel drive or two wheel drive, they should swap no problem. Just use the transfer case and driveshaft in your long bed. (If both have the same transfer case as well only the drive shaft really matters )
The transmissions are the same far as case size and dimensions.
Far as ticking it could be the clutch, but I've also seen transmissions make ticking sound like you describe and be broken.
Sent from my iPhone using Tapatalk Pro
I'll take some pictures when I get some time. But I just put a new clutch in 3 weeks ago
Was it making the same ticking noise before you changed the clutch?
No it was not. The ticking only started like 2 or 3 days ago
Then I suspect the clutch, not the tranny. Tranmissions don't usually "tick" when they go bad, anyway.
There was a Subaru once that made a weird ticking noise, I thought was just the clutch, apparently the transmission was all kinds of broken from what I was told but that's a different kind of transmission too.
I definitely would check the clutch and bearings before swapping
Well today it started effecting performance. I couldn't even take off in first gear because it was catching and grinding. Second gear did the same and third gear was loud but not at bad and 4th was the only gear I could go in where it wasn't extremely loud. 5th is really loud ticking. I can't drive it right now with the way it's acting so I'm gonna go ahead with the swap and check everything out while I do it
stop and drop that tranny before it leaves you stranded...
Is that "parked" on its side?
It's a southern thing, you wouldn't understand. ;)
Was going to say something about the southern thing :)
But then I saw you've got a earth mover now I'm jealous!
Hey, I'm south of the M-D line!  Born and raised.  (Not by much...but still south of it.)
