$40Custom Fit MJ headlight harness upgrades made by me Bismarck NoDak
895XJ
Alright guys I figured I'd post my little side project up on here. I bought a Putco hardness but there was a few things that I wasn't happy about so I decided to make my own. Some of the issues with the Putco were no fuse, wires too short, complex install and hard to find relays.
All the connections of mine are soldered, no crimp connectors here. Made of 16 gauge wire it makes a noticable difference. This isn't going to be a big number thing but I figured I'd make a couple extra to sell. Once I run out of supplies I'm gonna call it quits unless there's a big demand. Here's some pictures of them. The photos are taken without wire loom on them but that's just so you can see the splices. Any questions please ask!
Some features I'd like to point out that make this better than others are
It's fused
Universal five pin relays
Soldered connections
Custom length cut to XJ and MJ
High temp ceramic connectors
Easy install, one wire for ground and one for positive
Hand made attention to detail, individually tested.
00b73ef0070feea144a844ef90326678.jpg821ba62d7957f12e87c1afae8d861ccb.jpg669565fb5256e05836e3c8c05787bb72.jpgabd6c4e1daa041ab6ce816f62ad738da.jpg1e328545e857deab5c54708774b54448.jpg
Sent from my XT1635-02 using Tapatalk
Looks good, are you going to sleeve the wires at all?
Assume you will be using split loom since the harness is already soldered together? Nice work.
Opened up my harness package today.  It looks as good in person as it does in the pictures!  I even tugged on a few of the connections to see if they were tight or not.  Nice Work!
I put the harness back in the package and on the shelf - so I don't loose it over the next few months.  Once the 86 diesel MJ gets to California, the harness will be instaalled with a pair of Hella E-code headlights.  Once that is done, I should not need any extra driving lights.
Again, very nice work and a BIG thank you for putting these together.
Thanks John! All the connectors are crimped on and then soldered too so they won't be letting loose anytime soon. Thanks again for your order, I hope you enjoy. I'll have more ready shortly!
  • 3 weeks later...
  • 1 month later...
Archived
