ok guys here in the next month I'm going to be starting working on my 87 mj again and I'm re-doing the whole fuel system to prep it for a Eaton M90 supercharger!! i want to ear some opinions on  fuel injectors. i red a few forums that sat the Volvo injectors work best in the renix jeeps and the 4 hole bosch seams to be the most popular option. so i wana hear what results you have gotten with what. also, has any one used the bosch 12 hole injectors?
and if any ones got a boosted 4.0 out there lmk how your rig is set up!!
  • Replies 50
well without pulleys the m90 maxes out at 9-12 psi max, so supper low. no matter what ill need better injectors. as far as AFR I'm still trying to figure out a good way to adjust it. Renix doesn't leave much options as far as that. later down the road a ecm will come in but thats a ways down the road. but at the low boost ill be running the factory set up should be able to keep up.
thanx thats a huge help there!! i noticed one of the comments mentioned putting a 90' ECU in his 87 XJ. would there be any real benefit to doing this? obviously the 90' ECU would be tuned for the High Output engine, so what would be the end results?
Not tuned for the HO. That's another story. Put an 89 to 90 ECU in it. You'll love it.
any tips on where to get one? i don't trust the junk yard for electronics, and ant tips on replacing it? never really looked at it but just a glance.
Got a plan how you're going to tune the M90 on a Renix system?
well the m90 is a small low boost supercharger, in the thunder-birds where this version is from and even the gran ams that use them they use the same computers as the none boosted models. in "theory" the factory set up should be able to keep up. its only going to be running 12psi max anyways and I'm going to use a blow off valve and start at 6psi and work my way up in testing. I'm re doing the whole fuel system and have a 125psi fuel pump, o in theory if the o2s run lean the ecm should open the injectors more and with me new fpr I'm using i should be able to meet the necessary fuel requirements, I'm still trying to figure out if ill have to do anything with timing or not yet. at such low boost i don't expect ill have to retard timing any.
I did a Miata with 10 pounds of boost from a supercharger and had to have timing retard, an auxiliary fuel pressure regulator, knock sensor,  and an in dash O2 sensor reading. .
well i plan on having a wide band AFR gauge no matter what to monitor my AFR, and I'm already going to have a aftermarket boost referenced fuel pressure regulator that can do 3-65psi and having a custom fuel rail made, I'm also planning in running both a inrtcooler and a fuel cooler as well. the only thing i havent figured out is retarding/advancing timing if i need to and doing a knock sensor if i need one. how do you adjust timing on the 4.0? do use a timing light and turn the distributor or what i havent ever looked tbh
well i plan on having a wide band AFR gauge no matter what to monitor my AFR, and I'm already going to have a aftermarket boost referenced fuel pressure regulator that can do 3-65psi and having a custom fuel rail made. the only thing i havent figured out is retarding/advancing timing if i need to and doing a knock sensor if i need one. how do you adjust timing on the 4.0? do use a timing light and turn the distributor or what i havent ever looked tbh
By using an external controller wired into the ECU harness, like A Unichip or Split Second FTC. But that ain't going to work with a Renix. That's why I asked you above how you are going to tune it...........
so my options then to prevent knock are going to be with octane and fuel/air temp. hmmm from what I'm reading the ecu controls all the timing through the cps tht said theres no way the ecm can adjust timing based on sfr or be changed... that will take some thought. well if there wasnt road blocks on custom projects they wouldnt be fun right?  :laughin:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=boost+timing+retard+control
My Miata had an ECU like a REnix. It was a 1990.
AFPR to increase fuel pressure under boost. No new fuel rail needed. It fits into the fuel return line to the tank.
It had an add-on knock sensor that would retard the timing before detonation occured.
I'm only making a custom fuel rail so i can have -8 AN treads on each end and so i can place my regulator on my return side of my rail and eliminate oem regulator that probably wouldnt reference boost well. and from the basic search you turned me on to retarding the timing shouldnt be a issue ether, just have to find the right controller.
Was this your Miata? Do you drink Heineken?  :rotfl2:
139431-lotus-miata-mostfun25kfeature088g
