INjake89mj Posted December 21, 2016 Share Posted December 21, 2016 Never seen anything like this...any insight? I'm more than likely going to go back to original style rear suspension, but this has me curious. The Tokico Shock sticker would lead you to believe that the PO used that brand shocks, but the rear are Gabriel's and the horizontal rear shocks are Rancho's. Maybe the kit was made by Tokico? Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 21, 2016 Share Posted December 21, 2016 The helper spring on the rear leafs looks like a Hellwig unit, and the forward facing rear sway bar looks like a custom install from perhaps a Camaro. No idea on the horizontal shocks................. Has this rig been lowered a bit? Link to comment Share on other sites More sharing options...
INjake89mj Posted December 21, 2016 Author Share Posted December 21, 2016 It does not appear to have been lowered. I do not have a good side profile shot of it on all 4's to post. I am going to remove all the aftermarket stuff, other than the rear sway bar, and add a stock overload. Link to comment Share on other sites More sharing options...
WyoCherokee Posted December 21, 2016 Share Posted December 21, 2016 I am guessing it had a camper on it at some point judging by the rear overloads and the add on rear sway bar. The blue bar under the oil panappears to be a front frame stiffener. The rear shocks don't really appear to be doing much at that angle. Maybe they were setting it up for drag racing? Link to comment Share on other sites More sharing options...
Hippie66 Posted December 21, 2016 Share Posted December 21, 2016 Possibly traction bar/anti axle wrap kit? Link to comment Share on other sites More sharing options...
INjake89mj Posted December 21, 2016 Author Share Posted December 21, 2016 The front sway bar is made by Quickor. They went out of business in the early 90's. They were supposedly the ones who designed them for the jeep motorsports teams, or so I've read... Link to comment Share on other sites More sharing options...
Vintage Smoke Posted December 21, 2016 Share Posted December 21, 2016 Those "extra" weird looking add a leaves are overload springs for carrying extra weight or as a stop gap for sacked out springs. Either way they are not the best route to acomplish either. The forward shocks are usually called kicker shocks and are used in applications where the the rear axle rotates under acceleration causing the spring to twist into an "S" shape. When the spring unwinds it makes the rear tires "hop" and momentarily loose traction....then twist again....then hop again....etc. As was mentioned earlier the rear sway bar is definitely a home made set up. Also as was mentioned earlier it all adds up to someone having an issue with extra weight in the bed....mostly a camper top which would have the weight up high and make the truck want to lean side to side in turns hence the sway bar. The gabriel shocks are also old school. Unless of course someone was just brave enough to road race a Comanche and wanted to optimize handling through the turns :rotf: Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 21, 2016 Share Posted December 21, 2016 The front sway bar is made by Quickor. They went out of business in the early 90's. They were supposedly the ones who designed them for the jeep motorsports teams, or so I've read... http://comancheclub.com/topic/9465-quickor-front-performance-swaybar-install/?hl=quickor Link to comment Share on other sites More sharing options...
mikekaz1 Posted December 21, 2016 Share Posted December 21, 2016 the eliminator was their "performance" trim model. not surprising someone set it up for what looks like a track kit. HD front trac bar, rear trac bar, spring stiffiners, rebound shocks, ect... Link to comment Share on other sites More sharing options...
INjake89mj Posted December 21, 2016 Author Share Posted December 21, 2016 Their is no proof that I can see that shows that this had a topper or camper shell. No holes in bed rails, no scratches in paint, no clamp marks. It does not have a hitch either, just ball on factory step bumper. Doubt it was installed for weight factor. If i had to guess, I'd say the previous owner was trying to get it to handle, which I find way cool! I will keep rear sway bar on it, but might not be the current one. Unless of course someone was just brave enough to road race a Comanche and wanted to optimize handling through the turns :rotf: like this... Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 21, 2016 Share Posted December 21, 2016 Their is no proof that I can see that shows that this had a topper or camper shell. No holes in bed rails, no scratches in paint, no clamp marks. It does not have a hitch either, just ball on factory step bumper. Doubt it was installed for weight factor. If i had to guess, I'd say the previous owner was trying to get it to handle, which I find way cool! I will keep rear sway bar on it, but might not be the current one. I don't think the SCCA MJs even had rear sway bars, but am not positive. Ben? I like how the bar is mounted on your rig. I mocked it up in various configurations on my LWB but never found the right bar as the fuel tank always got in the way. So I ended up going similar to the S10 factory-type setup picture below. It is a good upgrade for a street truck. Link to comment Share on other sites More sharing options...
INjake89mj Posted December 21, 2016 Author Share Posted December 21, 2016 I have an Addco sway bar for an old body style Dakota that I plan to use on the rear. I wonder if the bar is forward facing because it would interfere with the add on shocks? I have some old "mini truck" accessory catalogs at home. I'm going to look and see if I can't see anything similar tonight, maybe get a manufacturer name. Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 21, 2016 Share Posted December 21, 2016 That can't be your truck Don, too much dirt and grease. :rotf: Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 21, 2016 Share Posted December 21, 2016 I have an Addco sway bar for an old body style Dakota that I plan to use on the rear. I wonder if the bar is forward facing because it would interfere with the add on shocks? The ADDCO bar has a crappy mounting system on the SWB MJs - it uses "L" brackets on the upper shock studs to mount. I know guys who have them and are less than happy to put it mildly. That can't be your truck Don, too much dirt and grease. :rotf: Lol. No Mike, that's a pic of the factory optional ZQ8 bar on an S10. That bar would probably work fine on a SWB MJ with different end links. There are plenty of them on Ebay. Here's a cleaner one: Link to comment Share on other sites More sharing options...
INjake89mj Posted December 21, 2016 Author Share Posted December 21, 2016 I have an Addco sway bar for an old body style Dakota that I plan to use on the rear. I wonder if the bar is forward facing because it would interfere with the add on shocks? The ADDCO bar has a crappy mounting system on the SWB MJs - it uses "L" brackets on the upper shock studs to mount. I know guys who have them and are less than happy to put it mildly. Thanks for the input! Link to comment Share on other sites More sharing options...
Eagle Posted December 22, 2016 Share Posted December 22, 2016 The helper spring on the rear leafs looks like a Hellwig unit, and the forward facing rear sway bar looks like a custom install from perhaps a Camaro. No idea on the horizontal shocks................. Has this rig been lowered a bit? The horizontal shocks are to control axle wrap. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 22, 2016 Share Posted December 22, 2016 :yes: No worries about axle wrap with that rig. Link to comment Share on other sites More sharing options...
INjake89mj Posted December 29, 2016 Author Share Posted December 29, 2016 :yes: No worries about axle wrap with that rig. haha nope not in this truck! This is the closest thing I could find in my catalog. also found this while I was searching! Pretty cool. Link to comment Share on other sites More sharing options...
gogmorgo Posted December 29, 2016 Share Posted December 29, 2016 I wonder why Toyotas cost $20 more? Huge price jump. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 29, 2016 Share Posted December 29, 2016 I wonder why Toyotas cost $20 more? Huge price jump. Metric hardware? It was pricey then... Link to comment Share on other sites More sharing options...
