Clutch or Tranny?
So in the last week when driving at times, but not every drive,  my transmission is grinding when shifting gears.  Seems to happen the most with 3rd gear, and mostly downshifting. Also seems to happen after being on a the highway and not changing gear for a long period.  But could also just be that's how my recent driving have been.  Yesterday it happen, and then when I stopped at a light I wasn't happen to get into any gear.  I pumped the clutch a couple times and then I was able to shift. And had no problems the rest of the drive.  I did change the Transmission fluid back in Sept with Regline 75w90.  And yes I have the dreaded Ba tranny.
So here is what I have done so far.  I topped off the fluid, it was low but not extremely low. I took for a spin, no issues.  I then decided to take it for another ride later, and after I got out of the driveway, when I pushed the clutch in, there was a spinning noise. The pumped the clutch and it stopped. Happened one more time before I parked it.  Was not able to bleed due to weather and not having items nor someone to assist.
Update:  I attempted to do a gravity bleed, when I turned the bolt by the nozzle, not sure what else to call it, coming from the slave the whole nozzle SEEMS to be turning. This normal, as in the videos I have watched it didn't happen.  And to get to it with a wrench is a real PITA, and have to move the tube out some. I am worried I will do more harm than good.  I am going to schedule to get the Master and Slave replaced.
Like described above hold the "round" thicker section the bleeder screws into with vice grips then turn the bleeder out ( a bit of PB blaster or other penetrating oil sprayed on some time before will be a great help)
(I always use a socket on the screw to prevent stripping......or you can replace the bleeder screw ....maybe try a speed bleeder?)
